Safe boost for me, please help guys no idea what to look for.
Old Jul 13, 2004 | 05:25 PM
CivicSiRracer69's Avatar
Default Safe boost for me, please help guys no idea what to look for.
heres my mod list please someone tell me what is a safe psi level?
Head:
95' D16z6 head
Port and polish
3 angle valve job
Polished Combustion chamber
1mm hone on intake and exhaust ports
ARP Head studs
Crane cams 59300
Crower 1mm over sized valves
Crower Retainers
comp valve springs
Powder coated valve train girdle
Hondata Intake gasket
Top fuel Turbo gasket
Mugen Valve cover
Vti Vtec Soleniod
Air & fuel & Spark
Venom Intake manifold tapped for single N20 nozzle
Venom Fuel rail
Aeromotive FPR
RC 550's Saturated
Aem 69mm Throttle body
Glock Performance TB spacer
Extreme Customs IACV Doubler
MSD Blaster coil
MSD cap
MSD SCI
10.5mm OBX wires
Block:
93' D16z6 block
Decked
bored
honed .5mm for oversized pisons
Golden eagle Block guard Hone matched to sleeves
JE/SRP 9:1 .5mm over size
Eagle H Beams
polished RMR crank
Trans:
99 Vti Trans W/ oem LSD
ACT Pro light Fly
ACT 6 puck unsprung
ACT heavy duty PP
Cryo treated
B&M Short shifter
Poly bushings
Y8 steel shifter forks
theres more...
Turbo goodies:
ss Tubular Manifold
Precision T3T4 60 trim
Tial 35mm With 1 bar spring
Turbo X's RFL
3" Down pipe
Carsound 3" cat.
Custom mandrel 3" cat back
Apex'I N1 3" mufflar
Turbo X's Boost controller
3 bar map sensor
2.5" Intercooler piping
2" Wastegate piping
Golden Eagle Vacuum manifold
HKS Filter
30 X 6 X 2 FMIC
What do you guys think is a good PSI setting for me?
P28 With Uberdata, BTW if anyone here is good with uber files please pm me I need help.
Old Jul 13, 2004 | 06:36 PM
Nas_logic's Avatar
Default Re: Safe boost for me, please help guys no idea what to look for. (CivicSiRracer69)
why is your wastegate set at 1bar=14.50 psi? sounds like you can push that quite easily
CivicSiRracer69
Sep 16, 2004 09:57 PM
CivicSiRracer69
Sep 7, 2004 06:00 PM
cnydelSolHybrid
Jun 25, 2003 02:53 PM
