can't find this torque spec anywhere.
Old Jul 13, 2004 | 03:14 PM
HatchBox's Avatar
Skoobie no more...
Default can't find this torque spec anywhere.
the circled bolt the holdes the fuel line onto the fuel pump assembly
Old Jul 13, 2004 | 03:17 PM
crxgator's Avatar
Default Re: can't find this torque spec anywhere. (HatchBox)
man you change your name more than your underwear...
Old Jul 13, 2004 | 03:19 PM
beavis's Avatar
until it stops leaking
HatchBox's Avatar
Skoobie no more...
Default Re: can't find this torque spec anywhere. (crxgator)
sorry, hybrid hatchback was to long, this is it, i swear
Old Jul 13, 2004 | 03:20 PM
HatchBox's Avatar
Skoobie no more...
Default Re: can't find this torque spec anywhere. (ZCed89hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZCed89hatch &raquo;</TD></TR><TR><TD CLASS="quote">until it stops leaking</TD></TR></TABLE>
ok so i have to put the tank back in... turn the car on look for leaks then take the complete tank back out..... you OBVIOUSLY have never dropped your gas tank.
Old Jul 13, 2004 | 03:54 PM
mr. carpenter's Avatar
when i did mine i tourqued it pretty tight. with new crush washers it should seal up okay. that's the banjo bolt correct? i know the banjo bolt on the fuel filter tourques to 132 IN. lbs which is 11 ft. lbs i believe. use whatever name you want but keep the avatar. my wife makes me find it for her everytime i'm on the board. she loves it.
Old Jul 13, 2004 | 04:02 PM
HatchBox's Avatar
Skoobie no more...
Default Re: can't find this torque spec anywhere. (mr. carpenter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. carpenter &raquo;</TD></TR><TR><TD CLASS="quote">when i did mine i tourqued it pretty tight. with new crush washers it should seal up okay. that's the banjo bolt correct? i know the banjo bolt on the fuel filter tourques to 132 IN. lbs which is 11 ft. lbs i believe. use whatever name you want but keep the avatar. my wife makes me find it for her everytime i'm on the board. she loves it. </TD></TR></TABLE>
haha that was my goal to please the wifes of honda-tech'ers
djtsmith007
Oct 30, 2007 03:57 PM
eMpAtHy
Feb 9, 2005 04:45 PM
typeeg
Jun 7, 2004 01:33 PM
Charlie Moua
10
Sep 22, 2003 11:59 AM
CRiSP
Apr 19, 2002 10:31 AM
