Did not pass smog Nox Please help!!!
Old Jul 13, 2004 | 03:01 PM
Spence's Avatar
Default Did not pass smog HC Please help!!!
Well i did not pass the smog test by just a little bit the standard is 1.20 and i did a 1.47. You guys have any suggestions
sorry guys its the HC level
Modified by Spence at 6:31 PM 7/13/2004
Old Jul 13, 2004 | 03:27 PM
Spence's Avatar
Default Re: Did not pass smog Nox Please help!!! (Spence)
up!!!!!!!!!!!!!!!!!!!!!!!!!1
Old Jul 13, 2004 | 03:49 PM
95civicracer's Avatar
run the **** out of the car then test it. also run a lower test gas (87). then if that does not work it will be maintance time.
Old Jul 13, 2004 | 03:56 PM
delScho's Avatar
Do a quicky search. This was just covered. NO and NO2 are formed due to high combustion chamber temps and can also get past a bad catalyst in low numbers. A temporary fix is turning the timing back, but that can result in other problems with emissions. I don't think just running 87 will fix this as much as it might make it worse.
Old Jul 13, 2004 | 04:03 PM
taz77's Avatar
New User
1.2? the numbers should be in the hundreds...
Old Jul 13, 2004 | 04:34 PM
Spence's Avatar
ummm taz not in oregon man
Old Jul 13, 2004 | 04:42 PM
TwistedSI's Avatar
I've heard a lot of people adjusting their timing to pass in OR. I've never heard of using 87 octane, I was always told to use higher octane.
Are they using a sniffer? If so you could just run an alcohol mixture or some methonal. If you can get your car to run on it you will pass. I've never had a problem but every time I re-register I tell them I live outside of DEQ and they never argue with me. I've never had to run through even though I am technically supposed to.
Old Jul 13, 2004 | 07:37 PM
Spence's Avatar
Default Re: Did not pass smog HC Please help!!! (Spence)
up help
Old Jul 13, 2004 | 07:47 PM
taz77's Avatar
New User
Default Re: (Spence)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spence &raquo;</TD></TR><TR><TD CLASS="quote">ummm taz not in oregon man</TD></TR></TABLE>
oh, my bad... i thought u were talking about the nox. but 1.2? is that 1.2 ppm or 1.2%?
what were your o2, co, and nox levels at?
666JTK666
Jan 31, 2016 03:49 PM
langjairicer
May 28, 2010 01:13 AM
rotascircuit
Oct 10, 2009 09:28 AM
snowblind7x
May 19, 2006 03:35 PM
SimbaDogg
Jul 2, 2003 01:08 AM
