Whats wrong with my car?
Old Jul 13, 2004 | 01:48 PM
98AccordEX's Avatar
Default Whats wrong with my car?
i have a B16 swapped into my 90 Civic DX. everything worked fine. it started right up 3 straight times. but on the 3rd time it just shut off after about 2 minutes. (i let it run for about 15 minutes the first 2 times) now i cant get the car to start again. the fuel pump doesnt turn on and it doesnt spark at all. but the starter does turn on. the fuel pump will turn on when just running a wire from the battery to the pump so i dont think its the ground. i turned the key to acc. and jiggled almost all the wires around and the pump didnt turn on at all. so i dont think anything it loose. does anyone have any ideas? ignition switch? main relay? something else?
something is draining the battery now also. i checked it before and it read 12.08. now 10 minutes later it is reading 8.86. does that mean something is shorted?
Modified by 98AccordEX at 10:59 PM 7/13/2004
Old Jul 13, 2004 | 02:03 PM
tilt's Avatar
Default Re: Whats wrong with my car? (98AccordEX)
sounds like a short/miswiring somewhere. might want to check for any codes.
Old Jul 13, 2004 | 02:16 PM
98AccordEX's Avatar
Default Re: Whats wrong with my car? (tilt)
the ECU doesnt flash and the CEL doesnt come on either. at first i thought maybe it was a miswiring, but then why would it start and run fine and first 2 times?
Old Jul 13, 2004 | 02:40 PM
deftones0817's Avatar
im not positive but maybe somoene else can add on to what i say. Could it be the main relay if he isnt getting fuel?
DEF
Old Jul 13, 2004 | 02:52 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: Whats wrong with my car? (deftones0817)
check your fuses. you could have a short to ground. check the main fuse box then the dash. If your CEL dosent come on could be a bad ground.
Old Jul 13, 2004 | 03:09 PM
98AccordEX's Avatar
Default Re: Whats wrong with my car? (JC18)
i checked all my fuses. i'll just have to go through all my grounds and make sure theyre good. let me make sure i have them all.
tranny
thermostat
valve cover
battery
am i missing any?
Old Jul 13, 2004 | 03:12 PM
tilt's Avatar
yeah it could be the main relay. might want to resolder the pcboard. the solder tends to crack over time. if that doesnt fix it you should follow the instuctions in the helms manual - all you need is a multimeter to test the main relay and harness out. there is an online helms for the crx but i dont have the link... maybe someone here can link you to it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deftones0817 &raquo;</TD></TR><TR><TD CLASS="quote">im not positive but maybe somoene else can add on to what i say. Could it be the main relay if he isnt getting fuel?
DEF</TD></TR></TABLE>
Old Jul 13, 2004 | 03:35 PM
Nocturnal_Lude's Avatar
If I am understanding this right, you are saying the fuel pump is not priming when you turn to acc. on the ignition right??? if so then its your ignition switch. We just had this issue in my homies hatch...it would try and crank but the ignition switch was failing so it wasnt sending the signal to the pump to prime...we switched it out the next day and she started right up with no probs since...but check you main relay and everything else suggested before you buy something you may not need...hth
Old Jul 13, 2004 | 03:43 PM
98AccordEX's Avatar
Default Re: Whats wrong with my car? (StripShowHatch)
would the ignition switch cause the distributor to not send spark to the plugs?
Old Jul 13, 2004 | 03:46 PM
I thought the issue was no fuel??? maybe I read it wrong, but if you not gettin fuel, it doesnt matter whether your gettin spark or not...cant ignite what isnt there right? but the ignition switch from my knowledge...please correct me if im wrong, activates the necessary electricals to start the car...i.e starter, dist, fuel pump....anyone else???
Old Jul 13, 2004 | 04:01 PM
98AccordEX's Avatar
thats what i thought also. thats why i didnt think it was the ignition switch because my starter works fine. i just went out to play with some stuff and realized that my CEL comes on whenever i connect the battery. the key isnt even in the ignition or anything. just when theres power in the car the CEL comes on
and yes the problem is no fuel. although i can solve that by just running a wire from the battery to the pump. but not getting spark shows me that its not just the fuel pump that isnt turning on
Old Jul 13, 2004 | 09:20 PM
98AccordEX's Avatar
anymore input to my problems?
Old Jul 14, 2004 | 01:38 PM
98AccordEX's Avatar
up
HoCi
Engine Management and Tuning
11
Jun 9, 2018 10:05 PM
GPC91
Aug 17, 2012 05:23 PM
sl0waccord
Mar 3, 2012 03:13 PM
Greg_MB
Aug 7, 2010 06:22 PM
gitchesum
Feb 28, 2009 05:39 PM
