Need Help! 00 civic Fog Lights problem
Old Jul 13, 2004 | 01:19 PM
g2_boosted's Avatar
Default Need Help! 00 civic Fog Lights problem
Hey Guys, I have a 00 Civic Si. And i have the factory foglights. I was installing Piaa bulbs into them this afternoon and after i installed them i went to test them and i heared a pop and i lost power to the unit. I think it is a fuse but does anyone know which one it is and if there is an inline fuse on the wiring harness?? Thanx
Old Jul 13, 2004 | 01:24 PM
AutoXer's Avatar
Default Re: Need Help! 00 civic Fog Lights problem (g2_boosted)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2_boosted &raquo;</TD></TR><TR><TD CLASS="quote">Hey Guys, I have a 00 Civic Si. And i have the factory foglights. I was installing Piaa bulbs into them this afternoon and after i installed them i went to test them and i heared a pop and i lost power to the unit. I think it is a fuse but does anyone know which one it is and if there is an inline fuse on the wiring harness?? Thanx</TD></TR></TABLE>
The fuse is inline with the wiring, located near the fuse box. I'm wondering why the fuse would blow after a light install though?
Old Jul 13, 2004 | 01:32 PM
g2_boosted's Avatar
Default Re: Need Help! 00 civic Fog Lights problem (EX_AutoXer)
No idea, I thoght it was a lil weird too, So the fuse should be in behind the dash then? or still near the motor?
Old Jul 13, 2004 | 01:33 PM
rdaggett's Avatar
fuse would blow if the wattage on the new bulbs are too high
YumVTEC's Avatar
Default Re: Need Help! 00 civic Fog Lights problem (rdaggett)
use a bigger fuse now.
Old Jul 13, 2004 | 01:38 PM
rdaggett's Avatar
Default Re: Need Help! 00 civic Fog Lights problem (YumVTEC)
if I can remember correct I think to calculate wattage .... it would be VOLTS X AMPS = Wattage
So if you had a 10 amp fuse in it, it would be safe to 120 watts which I think the stock ones are 35-40 watts each
I think the new bulbs are at least 60 if not more
try a 15 amp fuse
Modified by rdaggett at 3:01 PM 7/13/2004
Old Jul 14, 2004 | 05:02 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2_boosted &raquo;</TD></TR><TR><TD CLASS="quote">No idea, I thoght it was a lil weird too, So the fuse should be in behind the dash then? or still near the motor?</TD></TR></TABLE>
Yes, it's near the fusebox. You may have to look behind the kneeguards to find it. It'll be in a little plastic fuse holder. Don't go putting in a larger fuse until you can figure out what made the thing blow in the first place, if it is blown.
Bleakened
Nov 6, 2015 12:04 PM
recaroem2
Honda Civic (2001 - 2005)
Nov 5, 2008 01:58 PM
EJ8CIVIC
18
Feb 8, 2008 04:18 AM
rippinitup01
Mar 7, 2007 02:22 PM
allmotaR
11
Mar 31, 2006 08:03 PM
