brakes problem
Guys i did a brake job yesterday and when i pump the brake i get pressure with the car off but when i turn it off its soft again. i bled the two front brakes. cause i only change the two front brakes. its a 97 civic hacthback. on one of the sides i used a c clamp on the other side (front dirver) i took off the piston to bleed the brakes and the fluid came pouring out... i bleed the braks like 5 times and they its still happing.. there enough fluid in the master cylinder what can be the problem?????
The front are disc and the back are drums
Modified by xoutlawz00x at 3:39 AM 7/14/2004
jonshonda
Sep 19, 2006 02:33 PM
the soL that could
10
May 21, 2006 09:50 AM
