B20 Sleeves
Old Jul 13, 2004 | 09:48 AM
Crx0324's Avatar
Default B20 Sleeves
Alright, Im doing my homework but having little luck. What is the most COST effecitve place to get sleeves for a B20 block. I want something that can take some boost. I did some searches but I olny found two places one with now price and another for 2G's. Some Direction would be Koo
Old Jul 13, 2004 | 09:57 AM
Fstrnldr's Avatar
Default Re: B20 Sleeves (Crx0324)
i have all my shops work done at Benson's in santa ana CA ... not the easiest person to get in touch w/, but by far the best work i have ever seen. and isn't that was important w/ a sleeve job is quality over price?.
Brandon
Old Aug 9, 2004 | 12:13 AM
gen2integra2001's Avatar
Default Re: B20 Sleeves (Fstrnldr)
what do you think about taking a b2o block n just putting in a block guard with sum high compression pistons?
Old Aug 9, 2004 | 11:21 PM
CRVTEC0WNZJ00's Avatar
Block garud can distort cylinder sleeve bore if not put in properly, it can also sink deep into the block over time, plus it severly reduces coolant flow compared to stock. Dish out the cash for sleeves you won't regret that.
Old Aug 10, 2004 | 12:00 AM
Ti3d in's Avatar
Default Re: (CRVTEC0WNZJ00)
If you're going to sleeve, then just get a LS block. It's cheaper and easier to find. It'll make just as much power as the B20, and be much stronger.
Old Aug 20, 2004 | 12:37 PM
Default Re: (Ti3d in)
Correct you are.
Old Aug 20, 2004 | 09:47 PM
Default Re:
aight thanx for the tip
Old Aug 20, 2004 | 09:50 PM
rodimus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ti3d in &raquo;</TD></TR><TR><TD CLASS="quote">If you're going to sleeve, then just get a LS block. It's cheaper and easier to find. It'll make just as much power as the B20, and be much stronger.</TD></TR></TABLE>
other than the sleeves it's the same block. same crank.
but yah..get an LS to sleeve.
Aem-hatch
Jan 18, 2011 10:08 PM
lakai_19
May 21, 2007 02:25 PM
onebad3dr
Nov 16, 2004 07:46 PM
NCHATCH
Acura TL, RL & ZDX
Mar 4, 2003 08:50 AM
TypeR0149
Aug 22, 2001 12:32 AM
