obd0 to obd1
Old Jul 13, 2004 | 08:34 AM
EFin' Kyle's Avatar
Default obd0 to obd1
how do i convert my b16a1 to obd1 to pass smog. different wire harness or what?
Old Jul 13, 2004 | 08:48 AM
4drEF's Avatar
Keyboard Humorist
Default Re: obd0 to obd1 (crxstreetracer90)
To pass legally you need to have it approved by a certified referee.
After passing you will get a sticker that says it's legal for you to have that engine swap.
Some heads up - you need to have all the smog equipment that the engine came with originally. Since the B16 you have is most likely a JDM motor, you will have to find all the parts from a USDM car that came stock with the B16 (Del Sol I think). You will need the USDM ECU and everything the USDM car has - including the intake filter box or equivalent for THAT engine.
Depending on the referee, they may or may not let some things slide like the filter box. Some don't even check to make sure you have the correct ECU.
Old Jul 13, 2004 | 08:50 AM
slowpokesi's Avatar
Default Re: obd0 to obd1 (4drEF)
as far as converting your car to obd1 you will need, obd1 distributor, obd1 ecu, piggy back harness, and obd1 injectors
Old Jul 13, 2004 | 08:53 AM
Rywire's Avatar
Minimum that I would change would be the manifolds, ecu, obd1, 4wire 02, that SHOULD pass ya. If the ref is cool. Ryan
Old Jul 13, 2004 | 08:58 AM
crx_88_si's Avatar
Default Re: obd0 to obd1 (droppedcrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">Minimum that I would change would be the manifolds, ecu, obd1, 4wire 02, that SHOULD pass ya. If the ref is cool. Ryan</TD></TR></TABLE>
http://www.vtecfrog.com for obd0 -&gt; obd1 harness w/ subharness.
Old Jul 13, 2004 | 09:32 AM
EFin' Kyle's Avatar
Default Re: obd0 to obd1 (crx_88_si)
ECU OBD Conversion Harness Converts OBD0(88-91) to OBD1(92-95)$119.95 is this plus ecu what i need? also is this a good price?
Old Jul 13, 2004 | 10:52 AM
hatchinprogress's Avatar
i hate the reff
Old Jul 13, 2004 | 11:15 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: obd0 to obd1 (hatchinprogress)
Why don't all you cali guys get your cars registered in AZ or Nevada?
Old Jul 13, 2004 | 12:38 PM
Rywire's Avatar
Default Re: obd0 to obd1 (LSVTEC 91 Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">Why don't all you cali guys get your cars registered in AZ or Nevada?</TD></TR></TABLE>
Because Governor "alll be baack" made it that you have to regester your car after 30 days or more stay in Cali.
edit:
He didnt make the law, but he is pushing this law harder then ever before... so if a cop see the same car with out of state plates, then again within 30 days... He is required to issue a change of address request through the dmv. Or something very close to this.
Ryan
Old Jul 13, 2004 | 12:39 PM
Rywire's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxstreetracer90 &raquo;</TD></TR><TR><TD CLASS="quote">ECU OBD Conversion Harness Converts OBD0(88-91) to OBD1(92-95)$119.95 is this plus ecu what i need? also is this a good price?</TD></TR></TABLE>
Ya, seems good to me. I vote this one though. http://www.jkobdconversionharness.com/
Old Jul 13, 2004 | 12:50 PM
EFin' Kyle's Avatar
if i get a dc 4-1 header that is carb exempt do i still need the extra wires four line o2 sensor or whatever it is called? or doesnt it matter?
Old Jul 13, 2004 | 01:02 PM
Rywire's Avatar
Ya, get a carb legal header for a 99-00 civic si/94-97 del sol vtec. Place the 4 wire o2 in the collector pipe before the cat and wire it to the obd0-1 conversion harness. You can also get a Skunk2 IM for a 94-97 del sol vtec, thats also carb certified. Ryan
Old Jul 13, 2004 | 01:12 PM
EFin' Kyle's Avatar
tahnx it sux having to smog this thing.
Old Jul 13, 2004 | 01:25 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: obd0 to obd1 (slowpokesi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowpokesi &raquo;</TD></TR><TR><TD CLASS="quote">as far as converting your car to obd1 you will need, obd1 distributor, obd1 ecu, piggy back harness, and obd1 injectors</TD></TR></TABLE>
Not true on the injectors. You can remove the injector resistor and add the obd1 injectors, or you can keep it simple and keep the resistor and your factor obd0 injectors which saves a whole step.
Old Jul 13, 2004 | 03:57 PM
Rywire's Avatar
Default Re: obd0 to obd1 (Deetz)
they need to see the obd1 injectors for REF though.
tjlewis10
Oct 8, 2018 06:53 AM
sleepers91hb
18
Aug 16, 2010 11:17 AM
xsi90teg
Jan 29, 2009 07:32 PM
nikitad
Northern California (Sales)
Sep 29, 2008 07:31 PM
gtarwiz
Apr 29, 2005 09:17 AM
