tach install green wire to the ecu??
Old Jul 13, 2004 | 06:46 AM
ironchef25's Avatar
Default tach install green wire to the ecu??
can i just tap the ecu for my tach rpm wire instead of going all the way outside to the disb...and if so which pin.... also pix would also help.. i tried searching but all i found was to hook it up to the blue wire in the disbtrib..
Old Jul 13, 2004 | 06:54 AM
crx_88_si's Avatar
why not the wire behind the cluster? Whether your stock cluster has a tach or not, the wire is there.
Old Jul 13, 2004 | 06:55 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: (crx_88_si)
Hope this helps..
You want to tap into the RPM signal wire.
Old Jul 13, 2004 | 06:57 AM
ironchef25's Avatar
hmmmmmm i guess.will that be ok?what color is it?. do i have to take my sterring wheel to open the dang cluster.?? also i know the red is for power.. but where do i tap that to?
Old Jul 13, 2004 | 07:01 AM
ironchef25's Avatar
Default Re: (LSVTEC 91 Civic)
wow good stuff. i was thinking about my cluster but i dont want to go to all the hasle of taking that off. beside i already bought the wire.. lost my recipt. hahahhah oh well. thanks guys.
Old Jul 13, 2004 | 07:04 AM
Banned
Default Re: (ironchef25)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ironchef25 &raquo;</TD></TR><TR><TD CLASS="quote">but where do i tap that to? </TD></TR></TABLE>
The pinout for RPM Signal as shown.
Old Jul 13, 2004 | 07:14 AM
crx_88_si's Avatar
you can get power for the ign wire and light from here in the fuse box.
Old Jul 13, 2004 | 07:16 AM
ironchef25's Avatar
where the red circle right? ok.. will do..
wow, fast response. detailed and with pix..
i love this site.
Old Jul 13, 2004 | 07:21 AM
Banned
i love this site.
Don't we all?
Old Jul 13, 2004 | 07:27 AM
crx_88_si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ironchef25 &raquo;</TD></TR><TR><TD CLASS="quote">where the red circle right? ok.. will do..
i love this site.
Yep, where the circle is. You should be able to see two male spade terminals. Just crimp a female terminal on the wire and it plugs right in. great source for 12v ign or 12v lights on.
Old Jul 13, 2004 | 08:02 AM
ironchef25's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">
Yep, where the circle is. You should be able to see two male spade terminals. Just crimp a female terminal on the wire and it plugs right in. great source for 12v ign or 12v lights on.</TD></TR></TABLE>
so ill use both of them then. ill just connect the white(light) in one and the power (red) in the other..
Old Jul 13, 2004 | 08:44 AM
hatchinprogress's Avatar
yeah the site just hate when people get mad and be like use search, but we arehere to help noobs (like me)
Old Jul 13, 2004 | 09:01 AM
Banned
Default Re: (hatchinprogress)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress &raquo;</TD></TR><TR><TD CLASS="quote">yeah the site just hate when people get mad and be like use search, but we arehere to help noobs (like me)</TD></TR></TABLE>
What?
Old Jul 13, 2004 | 09:36 AM
91civicDXdude's Avatar
the other three "option slots" are ignition switched power, all time power, and light switched power
Old Jul 13, 2004 | 09:54 AM
ironchef25's Avatar
Default Re: (91civicDXdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude &raquo;</TD></TR><TR><TD CLASS="quote">the other three "option slots" are ignition switched power, all time power, and light switched power</TD></TR></TABLE>
wow. never knew that.. hmmm i guess ill just hook up my tach power and light to those.. instead of tapping the wires...im glad i made this thread.thanks for everything guys...
Old Aug 26, 2004 | 01:55 PM
Tyree's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">you can get power for the ign wire and light from here in the fuse box.
I know this is old but does it matter witch one of the options do you use for power and witch one do you use for the light source or does it matter
Old Aug 26, 2004 | 06:55 PM
ironchef25's Avatar
Default Re: (Tyree)
yah.. im not sure.. but i think from the red circled above.. right is power 12v and left is light.
kseriesdreams
Dec 26, 2010 04:56 PM
tanabe
Oct 14, 2006 02:18 AM
joecivic93
Jan 6, 2004 10:07 PM
pdcivic
14
Jun 25, 2003 09:26 PM
b20guy
Apr 11, 2003 05:12 PM
