1990 Accord Blue Smoke Problem
Old Jul 13, 2004 | 06:36 AM
Petekazel's Avatar
Default 1990 Accord Blue Smoke Problem
I have a lot of smoke coming out the exhaust. I changed the piston rings, head gasket, and sent the head out to get a valve job and get new valve seals. The piston walls appear to be ok. Anyone have any idea what this could be? PLEASE HELP.
Pete
Old Jul 13, 2004 | 06:48 AM
Justin Klemgold's Avatar
It's blowby.
Blue - Blowby
Black - Running Rich
White - Coolant in oil.
Old Jul 13, 2004 | 08:04 AM
accord91lx's Avatar
Default Re: (Justin Klemgold)
blue is oil
white means it burning coolant
and yeah black is running rich i believe
Old Jul 13, 2004 | 10:08 AM
under advisement's Avatar
Default Re: 1990 Accord Blue Smoke Problem (Petekazel)
Check your PCV and make sure it is working. A plugged PCV can cause over pressurization of the crank case which can lead to blow by and oil leaks. With the list of stuff you've already done that would be where I would start.
Old Jul 13, 2004 | 01:29 PM
Petekazel's Avatar
Default Re: 1990 Accord Blue Smoke Problem (under advisement)
I know its oil burning already, but the PCV is fine. Anyone have any other ideas?
Pete
Old Jul 13, 2004 | 04:22 PM
ZigenBallz's Avatar
valve seals...
pretty common place to check...
try both a compression test and a leakdown test and you should have your answer from those results...
Old Jul 13, 2004 | 05:29 PM
Default Re: 1990 Accord Blue Smoke Problem (ZigenBallz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZigenBallz &raquo;</TD></TR><TR><TD CLASS="quote">valve seals...
try both a compression test and a leakdown test and you should have your answer from those results...</TD></TR></TABLE>
If it were the valve seals, it would only do it after startup.
Old Jul 13, 2004 | 06:05 PM
Petekazel's Avatar
Default Re: 1990 Accord Blue Smoke Problem (Justin Klemgold)
I checked the PCV again, the hose was 50% pinched I chaged the hose. Do I have to let the car run for a while to fix the following?
I'm getting air pressure in the crankcase, I've heared that it could be a bad injector. I am not convinced. What you guys think could be causeing this air pressure? Also its like a white color smoke, that smells like gas. Its not the head gasket that has been changed.
Pete
Modified by Petekazel at 7:20 PM 7/13/2004
Old Jul 13, 2004 | 06:13 PM
pngfolife's Avatar
Blue smoke upon deceleration means worn valve guides or bad valve seals. High manifold vaccum draws oil past the guides into the combustion chamber.
Blue smoke when accelerating indicates bad/worn rings. Oil is drawn into the cylinder under load since vaccum in the cylinder is high from high piston speeds. If you are not getting excessive blow-by, oil control rings are bad. If blow-by is excessive, compression rings are worn.
Old Jul 13, 2004 | 06:32 PM
Petekazel's Avatar
Default Re: 1990 Accord Blue Smoke Problem (pngfolife)
It smokes while in idle and while you give it gas. The smoke smells like gas. Compression is around 160lbs accross all cylinders
Modified by Petekazel at 9:59 PM 7/13/2004
Old Jul 14, 2004 | 10:02 AM
pngfolife's Avatar
Was the engine overhauled or rebuilt? How many miles since then?
Old Jul 14, 2004 | 02:55 PM
Petekazel's Avatar
All I did to the engine was change the piston rings, head gasket, and I sent the head to a mechine shop to get a valve job and valve seals. Still after all that it is smoking like crazy. Now I am stuck and I have no idea what elce to do.
Old Jul 14, 2004 | 03:25 PM
ZigenBallz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Justin Klemgold &raquo;</TD></TR><TR><TD CLASS="quote">
If it were the valve seals, it would only do it after startup.</TD></TR></TABLE>
As opposed to what? Before startup?
Did you hone the cylinders before replacing the rings? or did you just slap new rings in there without checking clearances or having a machine shop take a look at the cylinder walls?
Old Jul 14, 2004 | 05:05 PM
Petekazel's Avatar
The car smokes constantly cold, hot, night, day, holidays too lol.
we just replaced the rings and there was no damage on the cylinder walls. Let me ask you a question, when you have your car running, while the oil cap is open fo you feel air pressure comming out?
Let me know
Pete
Modified by Petekazel at 1:25 AM 7/15/2004
Old Jul 14, 2004 | 09:12 PM
Yeah smartass....if it's the valve seals while the car is off, oil will seep down into the combustion chamber...the you start it up and it burns it off for a few seconds...get what I mean now? 1+1 = 2.
Old Jul 14, 2004 | 09:50 PM
IanCT's Avatar
When you replace the rings you should hone the cylinders because they are not a true cylinder shape, the rings wear a shape into the cylinder that's not visible to the eye. There's probably gaps and the oil is getting thru there. Run a feeler gauge of varying thickness between the walls and the rings, you might find some tight spots and some that are more loose.
But at least yours is running, I can't get mine timed right...
90datech
May 13, 2008 07:10 AM
j-bird20
Jan 11, 2007 05:59 PM
barney510
Jun 11, 2006 08:11 PM
91backslash
Jul 29, 2005 11:37 PM
deSigi
10
Aug 24, 2004 08:30 PM
