this motor better blow - part 2
Old Jul 13, 2004 | 05:41 AM
1point7T's Avatar
Default this motor better blow - part 2
just waiting for a clutch..
still gotta do a valve adjustment, and put in some spark plugs..
More pics here if you're bored..
Modified by 1point7T at 9:51 AM 7/13/2004
Modified by 1point7T at 9:54 AM 7/13/2004
Modified by 1point7T at 9:55 AM 7/13/2004
Old Jul 13, 2004 | 05:56 AM
RobbieG35's Avatar
12 Years Strong
Default Re: this motor better blow - part 2 (1point7T)
What is in store for it? I missed part one I guess
Old Jul 13, 2004 | 07:51 AM
ITRpwrdEG's Avatar
OH NO!
A pretty B17 block that got OWN3D by the Die Grinder. Poor block webbing.
You owe that block by buying a nice manifold now that doesn't sit the compressor so close. My votes would be for the LoveFab SST. Or be unique and get the headache of a time Sidewinder.
Old Jul 13, 2004 | 09:12 AM
Turbo E's Avatar
is it me or do those cams look really scored up?
Old Jul 13, 2004 | 09:15 AM
Mad Cow's Avatar
Default Re: (Turbo E 604)
I'm guessing that's molly lube.
Old Jul 14, 2004 | 07:11 AM
1point7T's Avatar
i know.... the poor block.... imagine my surprise when i couldn't get the turbo to bolt onto the manifold because the BLOCK was in the way...
bolt on kit my ***..
i thought about smoothing it out while it's still on the stand.. but i don't want it to lose even more of it's structural integrity.. haha
yeah, the cams are coated with assembly lube..
part 1 high points:
motor:
b17 block stock
b16 crank
b16 eagle rods
b16 arias flat-top 9.1 pistons 81mm
balanced bottom end
itr oil pump
b18c5 head
mild headwork
b16 cams
golden eagle adjustable cam gears
ctr intake springs
itr intake springs moved to exhaust side
ferrea ti retainers
stock itr valves
skunk2 intake manifold
aem fuel rail
aem fuel pressure regulator
450cc dsm 'bluetop' injectors
uberdata
turbo:
drag3 kit
turbonetics t3/t04e '54' trim
tial wastegate
hks ssqv bov
tranny:
stock [unfortunately]
clutch - action 2md
flywheel - act street-lite
Old Jul 14, 2004 | 07:16 AM
m R g S r's Avatar
b16 cams in a c5 head???
Old Jul 14, 2004 | 07:20 AM
1point7T's Avatar
Default Re: this motor better blow - part 2 (m R g S r)
i know.. but i'm already broke because of that list of parts.. and they had less mileage than the b17 cams.. (114K)
besides.. cams are easy to change.. i can get some later..
any excuse to tear the car apart is a good one.
Old Jul 14, 2004 | 07:29 AM
m R g S r's Avatar
Alright, just checkin.. . you better change them out soon. Did the b16 internals fit without any mods?
Old Jul 14, 2004 | 07:41 AM
X-Mazda 3 Racer's Avatar
Looks great. Keep us up to date on your progress!!!
Old Jul 14, 2004 | 07:54 AM
Drag_On's Avatar
Default Re: this motor better blow - part 2 (GoldenEagleMfg.com)
Thats a great set up.. That thing should REALLY rip.. Make sure that when you do your cams - you ante up for some 98 R cams. There have been some VERY nice gains proven on baller ser ups like your own.
Beautiful build. Great to see stuff like this going on..
Old Jul 14, 2004 | 08:13 AM
david@didrace.com's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1point7T &raquo;</TD></TR><TR><TD CLASS="quote">
i thought about smoothing it out while it's still on the stand.. but i don't want it to lose even more of it's structural integrity.. haha</TD></TR></TABLE>
I would smooth it out. All of the scratches and ridges act as stress risers which would make it more succeptable to cracking.
Old Jul 14, 2004 | 08:17 AM
JDMCRX's Avatar
Default Re: this motor better blow - part 2 (10-94-55)
Weird B16 crank and rods weird the deck hieght is different no?
Old Jul 14, 2004 | 08:28 AM
G
sh!t happens.
damn nice to see a built bastard motor i loved my boost bastard1.7.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">Alright, just checkin.. . you better change them out soon. Did the b16 internals fit without any mods?</TD></TR></TABLE>
and what he ask^^^^^^?
Old Jul 14, 2004 | 08:29 AM
boosted92's Avatar
Default Re: this motor better blow - part 2 (JDMCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCRX &raquo;</TD></TR><TR><TD CLASS="quote">Weird B16 crank and rods weird the deck hieght is different no?</TD></TR></TABLE>
B16 and B17 share the same deck height. It is the B18's and B16B's that have the taller height
Old Jul 14, 2004 | 09:45 AM
1point7T's Avatar
ok, i'll smooth out the block.. just for you man..
yeah.. it's a bastard, b16/b17/b18c5
i don't even know what to call it anymore..
i was calling it a 1.7T, but obviously it's 1.6 now..
i dunno, i just want it to run.. perfect, forever..
i'm probably going to need limited slip, and a new 4th/5th gears..
my tranny already has the shortest gears on any tranny..
3rd tops at 80, 4th at 110, and 5th at 135?
i had the turbo running on the stock b17 last summer, til i spun the rod bearing..
first gear is over fast (especially with uberdata + full-throttle launching)
second would spin if i didn't shift carefully, third and fourth were just fun.
but that was 8-10 psi, stock compression..
now the motor will be lower compression and less displacement..
i can't wait to play with this thing..
topsekret
Jan 13, 2003 02:04 PM
InfamousRS
Feb 2, 2002 07:10 PM
Turbo EG6
Nov 9, 2001 08:01 AM
