Cold and Warm Compression Test
Old Jul 13, 2004 | 04:07 AM
93H22ACX's Avatar
Default Cold and Warm Compression Test
What is usually the difference in compression numbers between cold and warm compression tests?
If the cold compression test shows an even number, would the warm compression test show the same result but with higher numbers?
Old Jul 13, 2004 | 07:59 AM
mmuller's Avatar
Mad Scientist
Default Re: Cold and Warm Compression Test (93H22ACX)
they say to do a compression test when hot, because as you know when hot metals expand and will give a nice ring seal.
But i did a compression test when cold and hot and made no difference, but i dunno...
Modified by mmuller at 11:25 PM 7/14/2004
Old Jul 13, 2004 | 08:14 AM
93H22ACX's Avatar
Default Re: Cold and Warm Compression Test (mmuller)
thanks...anyone else?
just wondering...because my cold compression test yeilded 265-270psi per cylinder....
Old Jul 13, 2004 | 08:41 AM
im_poor's Avatar
as longs as the cylinders don't vary to much.
Old Jul 14, 2004 | 05:08 PM
Tad's Avatar
Tad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93H22ACX &raquo;</TD></TR><TR><TD CLASS="quote">thanks...anyone else?
just wondering...because my cold compression test yeilded 265-270psi per cylinder....</TD></TR></TABLE>
woah thats good
Old Jul 14, 2004 | 06:59 PM
Bailhatch's Avatar
Default Re: Cold and Warm Compression Test (Tad)
why don't you try it and tell us what you find?
Old Jul 14, 2004 | 07:13 PM
Tad's Avatar
Tad
yeah do both
Old Jul 14, 2004 | 07:58 PM
Yosshaa's Avatar
Default Re: (Tad)
as tated before iw ould think you wobetter results (higher numbers) from a how compression test becuase of the metal rings expanding and sealing jus that lil much more.
Old Jul 14, 2004 | 08:58 PM
murtnabila's Avatar
Default Re: (ambition)
so will the sleeves n everything else.
Old Jul 15, 2004 | 02:33 AM
93H22ACX's Avatar
Default Re: (murtnabila)
the oil pump is being installed thats why i havent had the time....i'll let you know
ricanxplaya
27
Feb 9, 2012 03:17 PM
Got_soy
28
Aug 8, 2005 12:49 PM
Jordan_4WS
Apr 23, 2002 02:58 PM
