Questions for b20 vtec build.
97 b20b 00 itr head
1. what size and kind of drill bit i need to relocate the dowel pin and tap the oil feed line??
2. what are the torque specs for head with arp studs?
3. do i use the b20 headgasket?.. anyone know what is the price?
thanks for help!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bpowa »</TD></TR><TR><TD CLASS="quote">
97 b20b 00 itr head
You will not need a drill bit to relocate the dowel pins. If you buy a Golden Eagle Ls/Vtec kit you will get everything you need to Tap your Oil feed.
I went 22-36-68. Then went threw 4 heat cycles. Went back and Tq to 70.
Use the Golden Eagle Gaskett it has the dowel pins re located with out Modding it yourself.
thanks for help!
In plain english. If you have the cash buy a Ls/Vtec Kit from Golden Eagle.
97 b20b 00 itr head
thanks for help!
RA429
10
Jan 5, 2011 12:09 PM
Redsun
Mar 22, 2005 06:17 AM
