what engine wiring harness do i need?
Old Jul 12, 2004 | 10:11 PM
im done's Avatar
Default what engine wiring harness do i need?
im trying to put a gsr swap into my ek. i think its obd2
Old Jul 12, 2004 | 10:26 PM
Chris y0!'s Avatar
Default Re: what engine wiring harness do i need? (imc2pid)
if you have a 96-98 get a 96-98 EX harness
if you have a 99-00 get a 99-00 Si harness
Old Jul 12, 2004 | 10:37 PM
im done's Avatar
Default Re: what engine wiring harness do i need? (Chris y0!)
do i have to cut any wires? cuz some wires doesn't reach over im thinkin bout getting some 99-00 si engine harness
Old Jul 13, 2004 | 11:10 AM
Chris y0!'s Avatar
you're going to have to wire the secondaries on the intake manifold and extend the second o2 sensor i believe.
Old Jul 13, 2004 | 03:10 PM
Silverhatch's Avatar
not to jack your thread or anything. I am going through the same thing.. I have a 2000cx hatch and Im putting in a 99gsr swap. what harness do i need ? I tired to plug the gsr ecu into the stock cx harness and only 2 connectors fit.. Will the ex one work ? and also is the wiringharness in 2 pieces ? Or does it come from the ecu straight to the sensors ?
Old Jul 13, 2004 | 04:29 PM
im done's Avatar
Default Re: (Silverhatch)
i have teh ex harness because it goes straight to the ecu it plugs right up to the gsr ecu
CasperX
Mar 21, 2016 12:48 PM
goofyej6
Dec 15, 2007 05:04 AM
Katman
Aug 12, 2007 04:57 AM
ek9tl
Jun 6, 2006 10:11 PM
dry-ice
Mar 13, 2003 06:07 PM
