Lots of RPM's but little GO (HELP!)
Old Jul 12, 2004 | 07:31 PM
liquidscor00's Avatar
Default Lots of RPM's but little GO (HELP!)
My car has been feeling weak and sick.
1 - When I put it into gear, the RPMs go as normal, but the MPH go slower than usual.
2 - Also When I'm driving, or at a stop. The VTEC doesn't engage all the way. (I can hear it but no pull )
Funny cause I didn't notice these problems till I took it in to Acura for its 30,000 mile maintenance. So I decided to ask them when I did my Oil change recently. They said I had to do $80 diagnostic, but before I go throw $80 away. I was wondering if you HT members have had the same problem and what should I expect. From what I read, Acura dealers are shady and want to avoid as much misunderstandings as possible. I just hope it isn't anything big, my thoughts is the clutch. crossing my fingers.
Thank you guys for your time
Old Jul 12, 2004 | 07:33 PM
ZygSpeed's Avatar
Default Re: Lots of RPM's but little GO (liquidscor00)
Check your oil level.
Old Jul 12, 2004 | 07:43 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Check oil reset ECU. Consult HT again.
Old Jul 12, 2004 | 07:57 PM
kkim's Avatar
sounds your your clutch is slipping to me.
Old Jul 12, 2004 | 08:33 PM
Bbasso's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liquidscor00 &raquo;</TD></TR><TR><TD CLASS="quote">My car has been feeling weak and sick.
1 - When I put it into gear, the RPMs go as normal, but the MPH go slower than usual. </TD></TR></TABLE>
sound like a slipping clutch, I wonder how can anyone not know when your clutch is slipping
Old Jul 12, 2004 | 08:46 PM
DA6righthand's Avatar
im betting the clutch. if the motor doesnt sound different, and isnt giving you any probles but the slow acceleration, then its deffinately the clutch. my friend just had this problem with his ls.
Old Jul 12, 2004 | 09:48 PM
Ill's Avatar
Ill
Default Re: Lots of RPM's but little GO (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">
sound like a slipping clutch, I wonder how can anyone not know when your clutch is slipping </TD></TR></TABLE>
Clutch at 30K, especially hard driven, sounds right on. The trade off for easy feel and decent grab with R HP. Mine was not slipping, not damged (yet) but at rivets on one side at 40K. Was giving signs at 30K, and not THAT hard driven.
Any noises or chatter at clutch engagement prior to this?
Old Jul 12, 2004 | 10:23 PM
Seedc2's Avatar
Default Re: Lots of RPM's but little GO (Ill)
symptoms sound similar to my car my clutch is definately slipping
Old Jul 13, 2004 | 10:05 AM
When I press on the clutch it makes a squeeking sound, and sometimes its hard to put into gear like third. My car has 40K now, if it is the clutch. How much does a repair (replacement) plus labor run?
Old Jul 13, 2004 | 12:17 PM
nEoMuGen's Avatar
leave the car park on level ground with engine running, put in 3rd gear and let go of the clutch. If the engine does not stall right away, your clutch is slipping.
Old Jul 13, 2004 | 01:04 PM
genetsang's Avatar
"How much does a repair (replacement) plus labor run?"
i say no more than $400-$450
thats if you have everything for the install
Old Jul 13, 2004 | 01:05 PM
genetsang's Avatar
Default Re: Lots of RPM's but little GO (nEoMuGen)
"put in 3rd gear and let go of the clutch. If the engine does not stall right away, your clutch is slipping."
is that a proven way to see if the clutch is going?
cus i think mine is going.. but without ripping it apart.... i wouldnt know
Old Jul 13, 2004 | 01:28 PM
Dave-ROR's Avatar
Default Re: Lots of RPM's but little GO (genetsang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by genetsang &raquo;</TD></TR><TR><TD CLASS="quote">"put in 3rd gear and let go of the clutch. If the engine does not stall right away, your clutch is slipping."
if it's slipping bad enough...
you should be able to tell when it's slipping though, it's fairly obvious..
Old Jul 13, 2004 | 01:39 PM
Bbasso's Avatar
Once again <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote"> I wonder how can anyone not know when your clutch is slipping </TD></TR></TABLE>
if you give it gas and you see the rpm go up but your not going any faster then your clutch needs to be put in the garbage.
Old Jul 13, 2004 | 01:42 PM
itr1244's Avatar
or your clutch is slipping
Old Jul 13, 2004 | 02:49 PM
Default Re: Lots of RPM's but little GO (itr1244)
$400 to $450 parts and labor or just labor?
What pisses me off, is that my car was running great! and since the service tech guys seemed cool. I went ahead and did the maintance, and ever since then nothing seems right.
What really got me thinking that is wasn't just in my head. A couple of weeks ago I was driving and questioning my cars proformance. When I decided to test it, I figured that the ITR has pretty good acceleration. So maybe if I slow down and wait for car to pass me and see how long it took my car to catch up. I would slow down to like 60 and maybe a car past by like at 70-80 Well let me tell you, just about every car were giving me trouble. I would floor that gas pedal and the car feels the same, even when the VTEC engages. It doesn't even lunge or pick up speed, I can feel the motor kicking but no pull.
I was wondering could it also be my timing?
Old Jul 13, 2004 | 04:48 PM
genetsang's Avatar
most shops here on the eastcoast will charge roughly $250-$350 just for labor.
i said $400-$450 jsut for labor.... thats on the High side. (i.e. dealerships, famous performance shops)
Old Jul 14, 2004 | 09:55 PM
Ill's Avatar
Ill
West coast deal price labor is $300, expect more for a good shop. Parts from Len ran me about $300 (dont remember exactly, give Len a call) last month (clutch 'kit' - clutch [pressure plate], disk, throwout & pilot bearings). So I guess $600 - 750 (roughly, complete). I did the labor myself. I'm good, but gawd what a biznitch. Next time will be easier tho.
Old Jul 14, 2004 | 11:25 PM
MiraiZ's Avatar
best thing to do is supply your own parts and get someone with experience to install it with you
Old Jul 14, 2004 | 11:36 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Default Re: Lots of RPM's but little GO (MiraiZ)
If it's not the clutch check the distributor coils. Mine have went bad twice. Car pulls like butt on the top end.
Another way to check the clutch is to slam through the gears. If your rpms don't drop right away or at all (if you stay on it) thats a good sign lol.
Old Jul 15, 2004 | 09:42 AM
Default Re: Lots of RPM's but little GO (ActiveAero)
I'll try that, I haven't really driven Hard because I don't want to be without a car. I made a appointment with another dealership for tomorrow and will get back some info on what the car needs. I guess I'll take steps from there.
2k1 GSR
Mar 14, 2005 10:39 AM
Dels98R
Dec 4, 2003 10:39 AM
pleiades nutz
Dec 30, 2002 02:19 PM
2001TypeR
Sep 23, 2002 03:25 PM
Comptech98GSR
Oct 14, 2001 03:11 PM
