Help, I've got problems!
Well, I first noticed this yesterday but confirmed my disbeleif today. It seems that when I am taking a curve at high speeds at around 7k I will have sudden power loss for just a split second and then the car runs normally up to redline. I have no idea what could be wrong with #618.....she has been babied since the day I drove her off the lot oil changed every 3,000 miles and never abused till fully warmed up
. Any ideas as to what could be causing this? Any input would surely be appreciated! TIA
Thats what I was thinking....I havent had a chance to check it yet but the oil was changed not too long ago and the car hasn't been driven all that much......damn acura techs!
Checked the oil and it is bone dry, barely any shows up on the stick. Now my question is, how could it have gone through this much oil in just a little over a month? No track days, no autoxing, nothing.......none leaking anywhere, always parked in the same place and I dont think I could have gone through this much oil just by burning it in 1,088 miles without noticing a smoke screen. Do you think the tech at Acura didnt fill me up last time? I did a compression test about two months ago and I hit 210 across the board...please help!
Sure, the "tech" at Acura could've only put 4qts during the oil change. (required is what? 4.2-4.4 qts w/ oil filter). So, you could've started w/ at least 0.2-0.4 qts lower than usual and burned up even more in the past 1000 mi.
My recommendation: Do simple maintenance (i.e. oil & other fluid change) at home. So, you know what you put in and know how to diagnose such small problems.
As a rule I go by, everytime I open the garage door I open the hood and ck under the hood for all fluids and anything that might be out of place.
I strongly recommend this for all car owners especially if you care about the car you going to drive.
(and my friends wonder why it takes me so long to get from my house to where ever)
The dots on the oil dipstick: about how much oil do they represent??
I know the top dot means 'full', but what does the bottom dot show?
I've always been under the impression the area between the dots is one quart of oil.
Yep one quart.....which mean that I was 2 quarts shy
Must have been oil starvation, if you were that low on oil.
What kind of oil did u use before? I use Mobil 1 syn. When I took it to Acura for the 60k service they put Honda non syn. and it burned withen a week.
You had problems!!!
I just went by the dealer during my lunch break and they want to do a rebuild....but I dunno if I should trust them with that.
I think I am just gonna keep an eye on her and see exactly how much I am burning, I think the mechanic just didn't fill her up last time it was in for an oil change.
You guys think I did some major damage? I mean 2 quarts is pretty low, especially within about a thousand miles.....you think I should have her rebuilt?
They will do the rebuild for free!?
arterial_black
Nov 11, 2008 06:36 AM
