Y1 trans with LSD problems(very common?)
I found some old threads about the same problem that I"m having. I have a J1 trans but I swaped over the whole differential from a Y1. I took the differential apart by accident
and it had clutch disk in it, so I don't think it was a stock honda LSD, more like a aftermarket lsd. I"ve tried every axle combination possible and they don't work. Did the addictive work you guys, that you were trying.
And it has to be the LSD because before I swaped it over the tranny was fine.
and it had clutch disk in it, so I don't think it was a stock honda LSD, more like a aftermarket lsd. I"ve tried every axle combination possible and they don't work. Did the addictive work you guys, that you were trying.And it has to be the LSD because before I swaped it over the tranny was fine.
lovey408
21
Sep 6, 2007 07:35 PM
