how much?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head »</TD></TR><TR><TD CLASS="quote">a jack, a jack stand, socket wrench size 12mm
40-100 dollar, depend on the place, 15 minute job </TD></TR></TABLE>
Yeah, you can buy the 'proper equipment' for the amount a shop will charge. Plus you'd get some DIY experience
Yeah, you've got a jack in your car, Sears sells 2 and 1/4 ton rated jackstands for $15 a pair, and you can pick up an extremely basic socket wrench set for about $6-10 also from Sears if you don't already have a socket wrench. There's no other tools needed.
Keep in mind the bolts are prob all rusted on so basic tools will not be enough...a cheap 4" grinder with a cut-off wheel will save you much time and aggravation.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stew Pidasso »</TD></TR><TR><TD CLASS="quote">Keep in mind the bolts are prob all rusted on so basic tools will not be enough...a cheap 4" grinder with a cut-off wheel will save you much time and aggravation.</TD></TR></TABLE>
All my bolts came off with the socket wrench with minimal effort. I don't think a grinder is necessary, probably just some penetrating oil or even WD-40
2 Jackstands: $15
Hydraulic Jack: $20
PB Blaster: $3
Cheap set of sockets and a ratchet: $10
Hammer: who the hell doesnt already have a hammer?
Just stick the socket on the bolt and hit the ratchet with a hammer to loosen it up (after spraying PB Blaster on it, of course
). Now you'll have the satisfaction of knowing you did it yourself, and you'll have a little set of tools to work on your car in the future.
Hydraulic Jack: $20
PB Blaster: $3
No, from what I've seen PB Blaster penetrates much better than WD-40. WD-40 is good for cleaning and as an intial lubricant. For breaking rusted bolts free go with PB Blaster, it does wonders.
