shifter height
Old Jul 12, 2004 | 05:49 PM
iam94wcyy's Avatar
Default shifter height
i was wondering if there is a shifter out there is essentially the same as the stock integra shifter, but about 1-2 inches shorter, same throw, just shorter height.
thanks
Old Jul 12, 2004 | 06:35 PM
skunk2eg's Avatar
Default Re: shifter height (iam94wcyy)
i've found the gsr shifter to be the smoothest. aftermarket shifters grind to much
Old Jul 13, 2004 | 07:27 AM
iam94wcyy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam94wcyy &raquo;</TD></TR><TR><TD CLASS="quote">i was wondering if there is a shifter out there is essentially the same as the stock integra shifter, but about 1-2 inches shorter, same throw, just shorter height.
thanks </TD></TR></TABLE>
Old Jul 13, 2004 | 07:52 AM
SuzukaBlueAP2's Avatar
Default Re: shifter height (skunk2eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunk2eg &raquo;</TD></TR><TR><TD CLASS="quote">i've found the gsr shifter to be the smoothest. aftermarket shifters grind to much</TD></TR></TABLE>
I have yet to have a grind due to my short throw shifter after 2 years of use.
If all you want is a shifter that is shorter in height, and the length of the throw doesn't matter to you, then just cut and rethread a stock shifter.
Old Jul 13, 2004 | 07:53 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Grinding is due either to worn transmission components, possibly clutch problems, or more usually driver error. A short-throw shifter does NOT cause a transmission to grind.
BLUE EH3
62
Nov 4, 2007 03:16 PM
SoyMilk
Jul 12, 2007 08:39 AM
aandrewcc
Apr 23, 2007 08:47 AM
EGhatch33
10
Apr 27, 2006 10:03 PM
Kyles ej1
14
Oct 2, 2005 09:27 PM
