will 99-00 civic si wheels fit my 95 integra
just like the topic says..brought it to big 10 tires and said they dont fit because of the center hub part has a grove that doesn't connect and will wobble...my front passenger side wheels is making noises like the brake shield is rubbing against something...is that the problem? its an 95 rs by the way...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hbkxtbone »</TD></TR><TR><TD CLASS="quote">just like the topic says..brought it to big 10 tires and said they dont fit because of the center hub part has a grove that doesn't connect and will wobble...my front passenger side wheels is making noises like the brake shield is rubbing against something...is that the problem? its an 95 rs by the way...</TD></TR></TABLE>
they'll fit, an integra is basically a civic. Are u sure they're si wheels?
Sup man i work up at Discount Tire Co. down in Jacksonville Florida, if they fit on a civic they will fit on an integra. If you are hearing sounds, pull the tire off and see what its hitting and go from there you might need hub rings or somthing.
Vic
Vic
Chugger
Oct 8, 2001 03:36 AM
