Clutch is messed up. a little help... (long)
Old Nov 22, 2001 | 07:36 AM
E-AT_me's Avatar
Default Clutch is messed up. a little help... (long)
all was fine untill last night. i had a new, stock honda clutch put into my 90 CRX Si and it was fine. it dis-engaged at about mid-pedal, and felt smooth. last night, i was doing about 5mph on a road, then punched it while in first. i came to a stop sign, pushed the clutch in and took the car out of gear. when i put the car back in, and release the clutch, OH GOD!!! it was engaging/dis-engaging at the floor! in order to shift, i had to slam the pedal to the ground for it to dis-engage. i was able to make it home, and when i stopped my car with the clutch to the floor, it was still engaged and the car stalled. this morning i looked at it, and re-adjusted it. it's fine, but now the pedal is stiff and i can't feel a difference when the clutch is engaged/dis-engaged like i was able to before. any help please!
Old Nov 22, 2001 | 08:01 AM
Blown90hatcH's Avatar
Default Re: Clutch is messed up. a little help... (Rexman)
How many miles are on that clutch?
Old Nov 22, 2001 | 08:03 AM
Trinity's Avatar
Default Re: Clutch is messed up. a little help... (Blown90hatcH)
did you check your clutch cable also?
Old Nov 22, 2001 | 04:17 PM
E-AT_me's Avatar
Default Re: Clutch is messed up. a little help... (Trinity)
about 1000 miles ago, i already auto-xed on it, too.
i checked the cable, it seemed fine..
Old Nov 22, 2001 | 06:26 PM
rioninja's Avatar
Take a look at the actual clutch pedal itself, the clutch pedal brackets are known to eventually break on 88-91 civic/crxs. If that checks out, unhook the cable from the tranny and check it out by hand. Its possible that the cable has frayed inside the jacket. If the cable and pedal check out ok, then its gotta be inside the clutch itself. Could be pressure plate, throwout bearing, etc. Hopefully your tranny wont have to come off. Good luck
Old Nov 23, 2001 | 02:55 PM
E-AT_me's Avatar
Default Re: Clutch is messed up. a little help... (RioNinja)
thanks for the help guys. i installed a new clutch cable, and that was the problem. don't know why, it was just worn i guess. so for $60 i'm back and EF-en. i may be eas-en it soon....
MichealSenior
Feb 17, 2009 12:56 AM
fatfurious2
Sep 17, 2008 10:54 AM
ethereal2pt2
Nov 7, 2006 02:07 PM
mstolars
Nov 29, 2005 07:08 PM
ivanson
Mar 16, 2005 11:03 PM
