throttle problems
hey guys i need your help i have a 91 ef and i swapped a zc in it (classic). The motor cam with a broken tps sensor (also classic) but the car still ran fine with the engine light on. I drove the car for about 3 weeks and one night i lost power and the throttle was boucing all over the place but no response with the pedal. I change the throttle body from an 89 integra with a good tps. When i started the car up it purred nicely and the engine light did not come on. 30 seconds later my problem aroze again. HELP what do i do i just want to get it to run so i can sell it an move on to bigger and better things!!! im getting a crank angle sensor code and TDC code as well. All the connection are hooked up right some techs at my work think it might be the distributor. if you ahve any ideas im really stuck thanks
JasonLX
15
Nov 19, 2009 12:54 PM
