just replaced code 23(knock sensor) now i got a code 23(knock sensor) WTF!!!
obd1 jdm p30 ecu
obd1 b16a sirII
i broke the knock sensor when i first got the swap..then i kept getting code 23(knock sensor) so i replaced the knock sensor and now im getting a code 23 again(knock sensor)..my car is hot right now other wise id check to see if maybe it came loose and just need's to be tighten'd a little more..what else could it be..i mean the sensor detects knock in the block right? could it possibly be that?
obd1 b16a sirII
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGinNY »</TD></TR><TR><TD CLASS="quote">Maybe disconnect your batt. and reset the comp.....</TD></TR></TABLE>
Yeah.... What he just said.
yea that wouldnt have fixed it that would have just put a bandaid on it until it comes on again...anyways its fixed..it un threaded its self and was barely screwed into the block..now its all tightened up and wont be going anywhere
