what kind of grease is used to torque the head bolts down?
Old Jul 12, 2004 | 02:30 PM
sampol999's Avatar
Default what kind of grease is used to torque the head bolts down?
just as topic states.....would anyone happen to know what it is?
Old Jul 12, 2004 | 03:19 PM
DonF's Avatar
Default Re: what kind of grease is used to torque the head bolts down? (sampol999)
"Grease" was a movie with John Travolta, 30wt motor oil is what is used with stock head bolts and the fact. manual.
Old Jul 12, 2004 | 04:29 PM
hondaguyef's Avatar
Default Re: what kind of grease is used to torque the head bolts down? (DonF)
different manufacturers call for different kind of lubes when torquing head bolts. ARP gives different torque values if you are using 30wt than if you are using ARP moly lube. Do some reserach and use what the manufaturer calls for
Old Jul 12, 2004 | 09:11 PM
sampol999's Avatar
thanks guys....cant seem to find what the manufacturers want....thats why i asked u guys...i never knew that it was motor oil....just thought it was grease....since its thick and black.
Old Jul 13, 2004 | 03:11 AM
hondaguyef's Avatar
Default Re: (sampol999)
What head studs are you using and what engine are they going into? I will look it up for you or I may know off hand!
Old Jul 13, 2004 | 06:58 PM
sampol999's Avatar
theyre stock head bolts.....and there off a b16 and planning to put them back on. since i did a piston change over
mitoplease
Apr 21, 2009 06:48 AM
dumpeDc2
Nov 4, 2004 08:07 AM
ef8rex
Dec 24, 2003 04:32 PM
mEr
Oct 14, 2003 02:20 AM
