P28 error codes, how do I read them?
Old Jul 12, 2004 | 01:42 PM
pisetup's Avatar
Default P28 error codes, how do I read them?
I'm using a P28 ECU for the JDM D15B, if the ECU throws a code, how would I read it? The ECU doesnt have an indicator or anything.
Old Jul 12, 2004 | 01:47 PM
APEX CRX's Avatar
Default Re: P28 error codes, how do I read them? (pisetup)
Does your check engine light work?
Old Jul 12, 2004 | 02:04 PM
pisetup's Avatar
I haven't finished the swap yet. The old engine isnt even in yet. I'm just trying to get as much info. as I can get. This way, I'm prepared. But the CEL is working. Does it flash x amount of times and all I have to do is count how many times, and that's the error code?
Old Jul 12, 2004 | 02:08 PM
APEX CRX's Avatar
Default Re: (pisetup)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pisetup &raquo;</TD></TR><TR><TD CLASS="quote">I haven't finished the swap yet. The old engine isnt even in yet. I'm just trying to get as much info. as I can get. This way, I'm prepared. But the CEL is working. Does it flash x amount of times and all I have to do is count how many times, and that's the error code?</TD></TR></TABLE>
right, it will blink a certain amount of times something like this
1 fast blink then 2 fast ones count the blinks. Heres a chart you can use
http://www.c-speedracing.com/faq/05.php
Old Jul 12, 2004 | 02:15 PM
pisetup's Avatar
Awesome! That's what I thought would happen.
4drEF's Avatar
Keyboard Humorist
you need to jump a pin on the ECU to ground.
I forget what pin it is.
Old Jul 12, 2004 | 02:16 PM
pisetup's Avatar
Why would I do that?
Old Jul 12, 2004 | 02:26 PM
4drEF's Avatar
Keyboard Humorist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pisetup &raquo;</TD></TR><TR><TD CLASS="quote">Why would I do that?</TD></TR></TABLE>
If you don't then you CEL will just stay solid to alert you that your car is having issues.
You jump the pin to ground to let the ECU start sending the codes to the CEL light and let it blink. That's the way it works on the OBD1. The OBD0 ECU's have the clear window on the top of the ECU that you just look at and count the flashes. That's non-existant on the OBD1.
Old Jul 12, 2004 | 02:53 PM
pisetup's Avatar
Awesome! Thanks for the information guys! This will help out w/ my swap tomorrow. Thanks again!
in10ceCiviC
Feb 23, 2007 04:14 PM
rickturboteg
Oct 2, 2006 10:23 AM
UNKNOWN_MEMBER
Jun 9, 2005 08:09 AM
CPR
Jul 8, 2003 12:32 PM
4drGSR
Feb 23, 2002 10:53 PM
