need help installing suspension!
Old Jul 12, 2004 | 12:24 PM
RSVTECDC4's Avatar
Default need help installing suspension!
i just got new H&R and kyb agx gas shocks. i need directions on how to install them on my 94 integra rs with bone stock suspension. please help! please list the tools that ill need to. thank you
Old Jul 12, 2004 | 12:40 PM
RSVTECDC4's Avatar
Default Re: need help installing suspension! (RSVTECDC4)
anybody???
Old Jul 12, 2004 | 02:50 PM
LostAndFound's Avatar
go to team-integra.net they have an article how to install your new suspension. But basically you have to take out the LCA bolt, good luck. Bottom bolt on the damper fork, and the rear bolt on the fork, unscrew your brake lines from the strut assembly, and take off the two screws at the top of the strut that go into the engine bay. Then slide the strut and spring out, replace with the new one. TI has it all in depth
Old Jul 12, 2004 | 03:05 PM
timmy8151's Avatar
Default Re: (LostAndFound)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LostAndFound &raquo;</TD></TR><TR><TD CLASS="quote">go to team-integra.net they have an article how to install your new suspension. But basically you have to take out the LCA bolt, good luck. Bottom bolt on the damper fork, and the rear bolt on the fork, unscrew your brake lines from the strut assembly, and take off the two screws at the top of the strut that go into the engine bay. Then slide the strut and spring out, replace with the new one. TI has it all in depth</TD></TR></TABLE>
I used the TI article and didn't have too many problems. Yeah, watch out for the LCA bolt though. While you're at it, you might also want to inspect and/ or replace your bushings.
Old Jul 12, 2004 | 03:48 PM
tommymoose's Avatar
Default Re: (timmy8151)
You should also get a haynes manual... from amazon.com they're like 10 bucks
Old Jul 12, 2004 | 04:02 PM
burnout289's Avatar
Default Re: (tommymoose)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tommymoose &raquo;</TD></TR><TR><TD CLASS="quote">You should also get a haynes manual... from amazon.com they're like 10 bucks </TD></TR></TABLE>
or Kragen/Autozone! Haynes or Chiltons, both good.
Old Jul 16, 2004 | 11:20 PM
RSVTECDC4's Avatar
Default Re: (burnout289)
I CANT GET THE DAMN AXLE NUT OFF!!! I NEED HELP!!!!
Old Jul 16, 2004 | 11:25 PM
Danger's Avatar
Default Re: (RSVTECDC4)
any power tools ? if not get the jack handle and throw that on the ratchet
Old Jul 19, 2004 | 04:58 AM
burnout289's Avatar
get a long breaker-bar and put a pipe on the end for more length if you need it. don't be afraid to jump on it [not while the car is raised, tho...]
.colin
Northeast
Apr 13, 2008 09:59 AM
NineInchRails
Nov 1, 2005 04:58 PM
LBBP R
Honda S2000
Jul 30, 2005 06:13 PM
Kowalski
Mar 27, 2005 09:26 AM
MugenHonda
Apr 2, 2003 09:24 AM
