Does anybody know what the specs on this piston means?
Old Jul 12, 2004 | 12:12 PM
rice a roni's Avatar
Default Does anybody know what the specs on this piston means?
HONDA 1.6V(D16Z6)R/D:75mm/9:1
whats the 75mm stand for?
Old Jul 12, 2004 | 12:13 PM
JDMlyfestyle's Avatar
75mm bore. that is how wide the piston is
9:1 is the compression ratio. which means how much volume it takes up inside the cylinder
Old Jul 12, 2004 | 12:53 PM
TeamCracka's Avatar
Default Re: (JDMlifestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlifestyle &raquo;</TD></TR><TR><TD CLASS="quote">
9:1 is the compression ratio. which means how much volume it takes up inside the cylinder</TD></TR></TABLE>
Correction, it means it'll compress every 9 o2 and gas molecules into the space that one takes up at 1bar.
Old Jul 15, 2004 | 12:33 PM
Default Re: (TeamCracka)
so i have to bore the cylinder wall to be 75 mm? or 75mm more?
Old Jul 15, 2004 | 12:42 PM
butters's Avatar
Default Re: (allmighty2door)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmighty2door &raquo;</TD></TR><TR><TD CLASS="quote">so i have to bore the cylinder wall to be 75 mm? or 75mm more? </TD></TR></TABLE>
what motor are you going to install these pistons in? if the pistons are 75 mm, then you would have to bore your existing cylinders to 75mm.
Old Jul 15, 2004 | 01:22 PM
Default Re: (butters)
into a d16z6
Old Jul 15, 2004 | 01:23 PM
how wide is the d16z6 cylinders anyways? does anybody know where i can get a piston where i dont have to bore?
Old Jul 15, 2004 | 01:49 PM
civicminded92's Avatar
try using the search function. For example, type in "d16z6 bore"
https://honda-tech.com/zerothread?id=496636
WOW!!
Old Jul 16, 2004 | 12:54 PM
Default Re: (civicminded92)
oh ***** dude thanks
Dave_Dc2
Nov 3, 2008 10:48 AM
vinuneuro
Honda S2000
Jan 7, 2008 03:22 PM
ACrite3404
Apr 21, 2007 04:22 AM
doublejz
Oct 4, 2005 01:27 PM
Arch-Angel
May 9, 2004 06:48 PM
