increasing torque
Old Jul 12, 2004 | 11:01 AM
wasdayuca's Avatar
Default increasing torque
how can i increase torque ? is it possible to increase it with out horse power gain or do i just have to keep increasing the horse power with boltons and engine work? cuz b16a torque sucks
Old Jul 12, 2004 | 11:14 AM
97L-esVeeTeg's Avatar
Default Re: increasing torque (wasdayuca)
in my experiance...more displacement=more torque, bore it or stroke that beeotch
Old Jul 12, 2004 | 11:21 AM
wasdayuca's Avatar
Default Re: increasing torque (97L-esVeeTeg)
what do i have to get in order to bore it or stroke it ... whats the best method for a daily driven car dont want too much for it
Old Jul 12, 2004 | 11:32 AM
check out these two threads they should offer some help
https://honda-tech.com/zerothread?id=923029
https://honda-tech.com/zerothread?id=922913
also try contacting tech43racing inc. he's your best friend right now
Old Jul 12, 2004 | 01:45 PM
WAFFLES's Avatar
lightweight flywheel and a shorter(numerically higher) final drive will give you an increase in tq.
Old Jul 13, 2004 | 05:50 AM
Default Re: increasing torque (WAFFLES)
correct me if i'm wrong but i was under the impression that a lighter flywheel would HURT low-end torque not help, again correct me if i'm wrong. The final drive is a great idea
Old Jul 13, 2004 | 06:43 AM
wasdayuca's Avatar
wats a final drive ?
Old Jul 13, 2004 | 07:35 AM
B20JonLee's Avatar
Find old b18 shortblock. Use your pistons and the ls crank. This will give you more power and torque. Higher compression will require a re-tune but a great bang for the buck for streetable performance. You can recoupe some of your cost on short-block selling yours.
Old Jul 13, 2004 | 08:17 AM
WAFFLES's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97L-esVeeTeg &raquo;</TD></TR><TR><TD CLASS="quote">correct me if i'm wrong but i was under the impression that a lighter flywheel would HURT low-end torque not help, again correct me if i'm wrong. The final drive is a great idea</TD></TR></TABLE>
Think about it for a second. How could lightening the rotating assembly cause a loss of power?
Quicker revs with a shorter final drive will get you through the gears much faster.
Old Jul 13, 2004 | 08:28 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WAFFLES &raquo;</TD></TR><TR><TD CLASS="quote">
Quicker revs with a shorter final drive will get you through the gears much faster.</TD></TR></TABLE>
I wasnt sure, thanks for the info, i didnt want to spread any untrue info on H-T. When talking about lightened flywheels there are a bunch of opinions on H-T and you know what the say about opinions! But speaking from personal experiance more displacement does the job as well.
Old Jul 13, 2004 | 08:49 AM
WAFFLES's Avatar
But speaking from personal experiance more displacement does the job as well.</TD></TR></TABLE>
Can't argue that.
Old Jul 13, 2004 | 09:01 AM
to the original poster... what are your current mods, so we know which direction to go in.
Old Jul 13, 2004 | 11:37 AM
wasdayuca's Avatar
ok right now i have a b16a block from a 89-91 civc , 2000 usdm head and a 95 gsr tranny every thing that i just said is completely stock right now ...
Old Jul 13, 2004 | 11:55 AM
AngelR's Avatar
I wasnt sure, thanks for the info, i didnt want to spread any untrue info on H-T. When talking about lightened flywheels there are a bunch of opinions on H-T and you know what the say about opinions! But speaking from personal experiance more displacement does the job as well.</TD></TR></TABLE>
This is often said because you lose some inertia by going with the lighter fw... ie you may have to raise rpm slightly to break the tires loose or to pull the car from the line with the lighter fw as compared to the heavier stock piece. In contrast, if you are already in gear and rolling (clutch out) the lighter unit will show more tq everywhere and make rev matching easier.
Old Jul 13, 2004 | 12:26 PM
WAFFLES's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wasdayuca &raquo;</TD></TR><TR><TD CLASS="quote">ok right now i have a b16a block from a 89-91 civc , 2000 usdm head and a 95 gsr tranny every thing that i just said is completely stock right now ...</TD></TR></TABLE>
You have pretty much the same setup I have....I just added:
ITR manifold with Outlaw engineering gasket
milled head with mild bowl work
Fidanza flwheel
4.785 final drive
cam gears
My car is much stronger than before with the addition of these mods.
Old Jul 13, 2004 | 04:29 PM
Ekfoe's Avatar
i wish i knew to bore my b18c out before it got built, so i have the light flywheel and 4.7final drive, just got it done recently and i love it, but im sure it wont feel as fast after i get used to it.............if i had to do it over again i would do both bore and final drive......"no replacement for displacement"
prelude_93vtec
Sep 11, 2007 05:20 PM
pbink
Sep 22, 2005 12:05 PM
_Endless_
Mar 29, 2003 04:38 AM
