k20 swap info ? ? ?
Old Jul 12, 2004 | 10:04 AM
Rocks
Guest
Posts: n/a
Default k20 swap info ? ? ?
I just spent about 20 minutes searching under K20 swap looking for info on it in a EK chassis. I want to know what is exactly needed to do this and where could I get it. Thanks
Old Jul 12, 2004 | 10:09 AM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: k20 swap info ? ? ? (Rocks)
Everything needed but the header can be found at Hasport. From what I understand, the header is coming soon, but there are custom fabricators such a DTR that can make you one now.
PM brian g if you want to know more.
Old Jul 12, 2004 | 10:30 AM
Rocks
Guest
Posts: n/a
Default Re: k20 swap info ? ? ? (rochesterricer)
How about wiring. Could it be found there. Before I made this thread I went to their site and could not find anything on kseries wiring
Old Jul 12, 2004 | 10:45 AM
ShaunRR's Avatar
HT White Ops
Community Builder
They haven't updated their website yet, but it is all for sale right now. The pnp harness is 3 or 400 bucks.
hndarcrb18c1 will be posting the wiring info in a few days if you want to DIY. He says it is really easy, "Trust me when I say its easier than a B swap!!! I had the motor in the car in 10 minutes!"
Old Jul 12, 2004 | 11:02 AM
civicshowracing65's Avatar
i also heard the bitch part for our ek's is that you have to move the radiator to the drivers side
Old Jul 12, 2004 | 11:07 AM
93Civac's Avatar
A guy here in SC put a k20a2 in his 99 hatch, and hegot everything he needed form Hasport, but I think he paid like $600 for his harness.
He had to get the header custom made.
Old Jul 12, 2004 | 11:26 AM
6SPD_EK's Avatar
Default Re: (93Civac)
K20a or K20a2 swap
custom Axles (hasport or other)
custom header (hasport or other)
reflash of ECU (unless you plan to leave stock & use original key )
remount radiator or by a custom one (for RSX-S) & custom mount it
Motor Mounts (hasport or other)
custom fuel system: rail, lines, regulator (see https://honda-tech.com/zero...age=3)
EP3 (02+ civic si) idler pulley since you can't have power steering
EP3 throttle cable
K-series clutch slave cylinder
K-series/custom clutch line
90-97 accord or 94-97 Prelude shift box
Uncut engine harness for USDM K20a2
Uncut engine/charging harness (battery cable & alternator lines)
Uncut EK engine harness (hasports charge of $400 does not include the core you supply)
6 speed shift ****
engine temp switch/sensor (hasport or B series)
radiator hoses
heater hoses
resurface the clutch or get a new one
make sure you get the primary (wideband) o2 sensor
K series shift cables
if you are going to reflash or reprogram(K-pro) the ECU make sure you have all receipts & vin documention
unless you wanna ride around with 160-170 whp...I would get at least an ECU reflash if not the fully programmable K-pro ($990) & then get it tuned by a reputable shop/person
Modified by adirondackR at 3:52 PM 7/12/2004
Old Jul 12, 2004 | 11:28 AM
Nikos's Avatar
It is more complicated than B series but people are doing them all over the place.. EG and EK
Look at this last swap I saw today on my website k20a.org
Any questions you have, I would be happy to help... I am sure you understand why I cannot cover the whole swap.... Look at topics people have created includuing myself...
Old Jul 12, 2004 | 11:32 AM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: (Nikos)
I was waiting for you to chime in Nikos.
Old Jul 12, 2004 | 11:34 AM
Nikos's Avatar
Default Re: (rochesterricer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rochesterricer &raquo;</TD></TR><TR><TD CLASS="quote">I was waiting for you to chime in Nikos. </TD></TR></TABLE>
Thanks man... lol
That EK looks HOT@!! Cleaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaan
Old Jul 12, 2004 | 11:37 AM
Rocks
Guest
Posts: n/a
anybody know where I could get k20a2 swaps. R swaps are running about 5500 I could cut a big corner ther by finding a a2 swap
smnowell's Avatar
Default Re: (Nikos)
One thing I would like to know concerning the EK K-series swap is how low the oilpan hangs. I know on EGs the pan hangs incredibly low, especially with K20EGs mounts (basically the entire oilpan is below the bumper). I was wondering if EKs were the same way...
Old Jul 12, 2004 | 11:44 AM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: (Nikos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nikos &raquo;</TD></TR><TR><TD CLASS="quote">Thanks man... lol
That EK looks HOT@!! Cleaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaan</TD></TR></TABLE>
Yes it is.
Didn't you get some Hasport mounts for your own swap? How is that going?
Old Jul 13, 2004 | 10:54 AM
Rocks
Guest
Posts: n/a
Default Re: (b16a ferio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a ferio &raquo;</TD></TR><TR><TD CLASS="quote">One thing I would like to know concerning the EK K-series swap is how low the oilpan hangs. I know on EGs the pan hangs incredibly low, especially with K20EGs mounts (basically the entire oilpan is below the bumper). I was wondering if EKs were the same way...</TD></TR></TABLE>
any word on this
Old Jul 13, 2004 | 11:02 AM
6SPD_EK's Avatar
Default Re: (Rocks)
depends on how low your car is.... there is a separate thread on this https://honda-tech.com/zerothread?id=921571
basically looking at 4-6 inches IMO
Old Jan 23, 2005 | 02:51 PM
BLKCivicPorscheStyle*'s Avatar
Default Re: (adirondackR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adirondackR &raquo;</TD></TR><TR><TD CLASS="quote">K20a or K20a2 swap
EP3 throttle cable
6 speed shift ****
radiator hoses
heater hoses
Modified by adirondackR at 3:52 PM 7/12/2004</TD></TR></TABLE>
Wait a second! If you do the k20 swap into a 99-00 civic you can NOT retain your POWER STEERING??!?!
Old Jan 27, 2005 | 12:58 PM
supras4ever's Avatar
^ i would also like to know
Old Jan 27, 2005 | 01:16 PM
97ShLude's Avatar
No you can't retain power steering because there are hood clearance issues, even with the supporting cut out it still won't close.
Tomsidle
K Series
Mar 8, 2019 11:46 AM
live2tune4cvd
May 8, 2007 12:06 PM
jeffruby
Aug 19, 2006 12:33 PM
HondaRacer18
Feb 2, 2005 08:36 AM
