Car won't stay on....no acceleration either
Old Jul 12, 2004 | 09:58 AM
NTTKR's Avatar
Default Car won't stay on....no acceleration either
If I put some gas in the tb it starts but won't stay on.
I changed the injectors...same prob, then changed complete TB...same shiiit.
I'm thinking the main relay is dead......anyone knows what might be.
Old Jul 12, 2004 | 11:27 AM
NTTKR's Avatar
Anyone....????
Old Jul 12, 2004 | 11:41 AM
mymeatb18
Default Re: (NTTKR)
when you turn the ignition to on without startiung the car and dont hear the fuel pump prime then its the main relay my car had the same problem it wouldnt start used starterfluid and it stayed on until i pressed the gas then shut off. went to discount and got new main relay and now its fine
Old Jul 12, 2004 | 11:44 AM
NTTKR's Avatar
The funny part is that if i unscrew the fuel line form the TB, fuel comes out with enough presure...
Old Jul 12, 2004 | 01:36 PM
NTTKR's Avatar
If it's not the main relay ???...what might it be?
Old Jul 12, 2004 | 07:24 PM
dstahl01's Avatar
Default Re: (NTTKR)
Main relay replacement is about $55 and one bolt. Replace it and it will resolve your issue. Sorry to hear that you spent all that money on the injectors. In most cases the relay goes bad before the injectors. You can also open the relay and look for discoloration, if discolored it is probably bad. $55 will solve your problem.
Good luck,
Dave
Old Jul 12, 2004 | 08:36 PM
v8hunter03's Avatar
Default Re: (dstahl01)
make sure u hav gas in there... i kno some1 who had the problem and turned out the gas station pumper WATER!! he had i think it was 80% in the tank... never pump gas at a station where the tanker is filling up
Old Jul 14, 2004 | 02:13 PM
NTTKR's Avatar
well i bought the main relay...and guess whaaaaaat!!!
now i dont have fuel pressueeeeeeeeeeere!!!
ohhh I'm so maad.....what is wrong with my car :'(
Old Jul 14, 2004 | 03:18 PM
mr. carpenter's Avatar
Default Re: (NTTKR)
i vote fuel pump or fuel filter. when you say you have sufficient pressure do you mean it's spraying out like strong or just coming out? loosen the bolt at the fuel rail and turn the key on fuel should spray out like a shook up soda. if not then do th same at the filter's in hose. if you have spray there and not at the rail it's probably the filter. if no spray at the filter it's probably the pump or a blockage in the line.
Old Jul 15, 2004 | 07:27 AM
NTTKR's Avatar
Definetly my car is crazyyyy!!!
Yeah Mr.Carpenter I did that thats how i knew about the pressure..but guess what i went and put some more gas in the car so it would have more than half a tank and the fuel puuuuump started to work again....weird stuff don't u think...anywayss my car is running agaiiin I'm so happy
Thank u aaaaaaall for your help.
ckirso
Mar 18, 2013 08:08 AM
LS_teggy
Aug 5, 2010 08:41 PM
StreetEG
Jul 31, 2006 04:38 PM
DeviousCTR
Jun 28, 2006 03:43 PM
MooreBoost
10
Sep 8, 2004 07:43 PM
