How To R&R door lock actuator
Can anyone advise me on how to remove and replace the power door lock actuator on my 95 accord. I'm replacing the front pass side door and once the door panel is off and the plastic pulled back it seems very hard to get to the actuator. Also, the best price I've found is $54 shipped-anyone know where I can get one for less$$.
Thanks, Charlie
Thanks, Charlie
once you take the door panel off, you have to remove two screws from your door sill. Then you disconnect two rods, remove the exterior handle, and twist it aroud until its loose. Its really not that hard.
As for the parts, I recommend http://www.hondaautomotiveparts.com
