Tint Removal
Old Jul 11, 2004 | 09:27 PM
SoSoJeff's Avatar
Default Tint Removal
whats up guys does anyone know the most effective way to remove tint yourself?
Old Jul 11, 2004 | 09:44 PM
777sC's Avatar
Default Re: Tint Removal (SoSoJeff)
id also like to know
bump for you
Old Jul 11, 2004 | 10:31 PM
mikehawkBUiLT's Avatar
the method i used was to get a spray bottle and fill it half water/half soap. i used a razor blade to get the edge of the tint off enough so i could pull it and then just sprayed the soap water, pulled a little more, sprayed, pulled, etc (repeat as necessary).
the soap water helps disolve the glue but it wont get it off clean, it just helps get the film off. there will be a little glue stuck on the window so cleaning it w/ a towel and rubbing alcohol would work.
there might be better suggestions but i found this way pretty easy, cost effective, and not so time consuming. took about 15 minutes i suppose
Old Jul 11, 2004 | 10:43 PM
NrG's Avatar
NrG
Default Re: (EJcoupe)
yep. soappy water spray bottle.
Or you can spray the window down with water and put a plastic bag on it (tint side). Do this in the hot sun, and the tint will fall right off. It takes 10mins or so.
Old Jul 11, 2004 | 10:48 PM
integraXTC's Avatar
Default Re: (NrG)
dats what i heard, but i heard it with vinegar.
Old Jul 11, 2004 | 11:06 PM
SoSoJeff's Avatar
Default Re: (chitwn91rs)
nice thanks for the help guys....i just think certain cars look better without tint
Old Jul 11, 2004 | 11:07 PM
tilt.'s Avatar
Default Re: (SoSoJeff)
um...a razorblade, and some free time.
Old Jul 11, 2004 | 11:48 PM
Sound Streamin''s Avatar
Default Re: (NrG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NrG &raquo;</TD></TR><TR><TD CLASS="quote">yep. soappy water spray bottle.
Or you can spray the window down with water and put a plastic bag on it (tint side). Do this in the hot sun, and the tint will fall right off. It takes 10mins or so. </TD></TR></TABLE>
So you put the garbage bag on the inside of the window? Does this work well for the rear window? Im worried about ripping off all my defroster lines.
Old Jul 12, 2004 | 12:13 PM
well, you can't be too careful about the defroster lines cause even professionals **** em up. its damn there impossible to have all of them working again once you take off the tint.
Old Jul 12, 2004 | 12:15 PM
sandiegan's Avatar
when the cops popped me for my front window tint, i just got the edge off with a razor blade and that was it. came off clean... didnt need any soapy water or anything.
the tint had been applied within a year and was 5% so i dont know if that makes a difference
ejLday
Detailing
Mar 25, 2009 08:54 PM
dopamean
11
Jan 2, 2009 07:27 PM
1slowcrx
Paint and Body
15
Jan 27, 2008 09:05 PM
ITR32
Paint and Body
Jul 10, 2007 09:27 PM
EK k kay
Aug 23, 2005 03:36 PM
