how many pounds of boost should i run on a stock civic si
Old Jul 11, 2004 | 09:22 PM
jamal3693's Avatar
Default how many pounds of boost should i run on a stock civic si
does a vacc/boost gauge tell you how much boost your running.
Old Jul 12, 2004 | 01:19 AM
turbopimp's Avatar
Default Re: how many pounds of boost should i run on a stock civic si (jamal3693)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jamal3693 &raquo;</TD></TR><TR><TD CLASS="quote">does a vacc/boost gauge tell you how much boost your running.</TD></TR></TABLE>
Yes it does.
Old Jul 12, 2004 | 03:45 AM
JDMCRX's Avatar
What fuel management u using?
Old Jul 12, 2004 | 05:37 AM
Trak_Day's Avatar
New User
It depends man. You could be using a little greddy turbo or you could be using a t3/t04e or straight t4. too many factors, heres a thought though, anywhere between 7-11psi. Now if you want WHP numbers. if you have a nice fuel management and a good fuel setup you can tune a stock SI to 325-350whp. Its been done over and over.
Use the Search function and you will have your answer in moments! Good luck and dont blow anything up!
JDM_Acccord
Jul 5, 2007 03:24 AM
Azndude1983
Feb 15, 2006 02:24 PM
Sam1am26
Nov 26, 2004 06:51 PM
djickabod
May 9, 2004 11:28 PM
jdm civic
Jan 27, 2002 05:48 AM
