how many pounds of boost should i run on a stock civic si
Re: how many pounds of boost should i run on a stock civic si (jamal3693)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jamal3693 »</TD></TR><TR><TD CLASS="quote">does a vacc/boost gauge tell you how much boost your running.</TD></TR></TABLE>
Yes it does.
Yes it does.
New User
It depends man. You could be using a little greddy turbo or you could be using a t3/t04e or straight t4. too many factors, heres a thought though, anywhere between 7-11psi. Now if you want WHP numbers. if you have a nice fuel management and a good fuel setup you can tune a stock SI to 325-350whp. Its been done over and over.
Use the Search function and you will have your answer in moments! Good luck and dont blow anything up!
