Help Please (Frozen Bolt on Mount)
Old Jul 11, 2004 | 08:03 PM
steve_s's Avatar
Default Help Please (Frozen Bolt on Mount)
Im doing a jdm d15b swap into my 93 civic ex. Im in the process of taking the motor out the car and have everything unhooked expect the rear engine mount bracket.
There are 3 bolts, I have one of the three but 2 others are frozen. They arent rusted or anything just god damn stuck on. Ive tried my 140 ft lbs impact wrench like 10 times, no luck. Ive tried pb blaster, heat, breaker bars, no luck. I even broke a craftsman socket on it with the breaker bar.
What else is there to do? I need this car in working order ASAP so your help would be very much appreciated.
I have considered just cutting the bracket off but Im not sure If i want to tdo that.
Thanks...
Old Jul 11, 2004 | 08:07 PM
xerox445's Avatar
Default Re: Help Please (steve_s)
140 lbs is nothing....go to sears buy the 600 ft pound 1/2 inch gun, it has a black front and a colored hard plastic abs back, with a 4 position dial on it. Use it, and return it. It is the same gun basicly as the top of the line Mac, Matco, and Snap On with lower grade parts inside, but they share the same case. I personally would just keep the tool, but it may be on the expensive side. The craftsman will hold up great aslong as you oil it b4 and after use, dont abuse it, and dont use it every day (ie a shop). Then again its a lifetime guarantee
Old Jul 11, 2004 | 08:09 PM
steve_s's Avatar
Default Re: Help Please (xerox445)
Well the impact wrench i have is 340 ft lbs but my compressor only goes up to 140 psi. Wait so why would it be only 140 ft lbs lol? Forget that but i doubt the impact is at full capacity with the compressor.
Old Jul 11, 2004 | 08:11 PM
TURBOFTW's Avatar
if u can and there is nothing in the way get a mutane torch( the hand held ones??) and heat it up realllly well and i guarantee u it will come off....but i dont remember exactly everything that is around this bolt so double check...
Old Jul 11, 2004 | 08:12 PM
steve_s's Avatar
Default Re: Help Please (h22dude)
I hit it with a propane torch for 5 minutes, no luck.
Old Jul 11, 2004 | 08:17 PM
TURBOFTW's Avatar
wow really, the motor is out of the vechicle correct? if so keep heating it up and just a 1/2 ratchet if thats the biggest you have and try to find a bar or something to make it longer for more leverage and try then
Old Jul 11, 2004 | 08:19 PM
steve_s's Avatar
The motor is in the car. Im trying to disconnect the rear mount so I can take the motor out. I broke a freaken socket trying to break it loose.
Old Jul 11, 2004 | 08:20 PM
xerox445's Avatar
if you run your tools at 140 psi, then you have more problems then i thought....90psi max is what you opperate most air tools with.
Old Jul 11, 2004 | 08:21 PM
TURBOFTW's Avatar
ok im sorry but this is the mount connected to the tranny correct? why not just undo the one bolt for the back mount and yank it out and then worry about pulling the bracket off when its out
Old Jul 11, 2004 | 08:22 PM
steve_s's Avatar
At 90 psi the wrench feels powerless but if you say so.
What do you think about cutting it?
Old Jul 11, 2004 | 08:23 PM
steve_s's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22dude &raquo;</TD></TR><TR><TD CLASS="quote">ok im sorry but this is the mount connected to the tranny correct? why not just undo the one bolt for the back mount and yank it out and then worry about pulling the bracket off when its out</TD></TR></TABLE>
Because that bolt seems close to impossible to get to. If i need to I will clear stuff out to get it.
Old Jul 11, 2004 | 08:25 PM
TURBOFTW's Avatar
you CAN get to it....i use a air ratchet and it usually comes out.. the intake manifold is in the way but it can be done much easier
Old Jul 11, 2004 | 08:27 PM
steve_s's Avatar
Okay thanks, will try tommorow.
Old Jul 11, 2004 | 08:28 PM
TURBOFTW's Avatar
No probublem goodluck
Old Jul 11, 2004 | 08:30 PM
xerox445's Avatar
if he cant get it off with an air gun, theres no way in hell he will get it off with an air rachet.
If your gun is no good at 90, its because the internals beat to hell opperating at 140 psi...
I would try to get a 6 point socket on the bolt, 1/2 inch breaker bar, with a pipe on it, that should take care of it? Um, Righty Tighty, Lefty Loosey right? lol
Also, are you trying to turn a stationary nut instead of the bolt?
Old Jul 11, 2004 | 08:34 PM
TURBOFTW's Avatar
I said air ratchet because hes going to be takeing off a complete different bolt...
Old Jul 11, 2004 | 08:39 PM
steve_s's Avatar
Its not a stationary nut trust me. Hopefully i can this **** off. This is what I find prob the hardest part of the swap. Putting everything back on is gonna be cake in my eyes.
bizE23
10
May 26, 2013 05:50 PM
Emeraldbomber
32
Jun 10, 2012 09:29 AM
birdricer
May 17, 2007 05:03 PM
swiftstyles
Dec 23, 2004 05:35 AM
NA-GSR
Sep 20, 2002 07:38 AM
