GSR Turbo vs Type R stock
Old Jul 11, 2004 | 07:09 PM
rpj2k's Avatar
Default GSR Turbo vs Type R stock
five thousand bucks to spend...which way would you go?
Old Jul 11, 2004 | 07:11 PM
ZygSpeed's Avatar
Default Re: GSR Turbo vs Type R stock (rpj2k)
Turbo ... hands down.
Old Jul 11, 2004 | 07:14 PM
Mires's Avatar
Depends. Depends on what car it is going in. If it is a Type R than the stock motor but if its anything else than I say GSR Turbo. If your answer is the latter this is the wrong forum anyway.
Old Jul 11, 2004 | 07:57 PM
98itr0448's Avatar
The ARR motor is probably the better n/a setup, but if the choice is stock R or turbo GS-R, then get the turbo. I used to have a 96 gsr, and now having the ITR, the R is a much more fun car to drive and is surprisingly quick for a 1.8l 4cyl. The car I had before the R was a 93 300zx tt. It was pretty awesome in a straight line, or sideways , but as far as a daily driver, the R is awesome! Good Luck!
Old Jul 11, 2004 | 08:01 PM
B2FiNiTY's Avatar
Default Re: GSR Turbo vs Type R stock (98Itr-0448)
Turbo all the way.
Old Jul 11, 2004 | 08:04 PM
is3oo's Avatar
Default Re: GSR Turbo vs Type R stock (B2FiNiTY)
I'd have to say turbo as well.
Old Jul 12, 2004 | 02:45 AM
Tegontoast's Avatar
Default Re: GSR Turbo vs Type R stock (rowdy type R)
turbo
Old Jul 12, 2004 | 04:11 AM
DAsix's Avatar
NA>Turbo Lag
Old Jul 12, 2004 | 04:42 AM
Jon D's Avatar
Default Re: (DAsix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAsix &raquo;</TD></TR><TR><TD CLASS="quote">NA&gt;Turbo Lag</TD></TR></TABLE>
Nate if you find this sometime today post a pic of the T-shirt gangsta!
Fawk all Motor!
Turbocharge that biatch
Old Jul 12, 2004 | 06:40 AM
StupidSlowRSX's Avatar
Default Re: (B18C-Rsi)
fo the money spent to boost the c1.... why not setup the c5 with an all motor layout?
Old Jul 12, 2004 | 06:51 AM
Justin Klemgold's Avatar
This isn't a good question...the Type R isn't a drag car, it's a track car...with that said, if you are into tracking, definitely get the Type R. If you want to go fast, the Type R isn't for you anyways because that was not it's intended purpose...it's intended purpose was to take the curves...
Old Jul 12, 2004 | 07:33 AM
Jon D's Avatar
Default Re: (StupidSlowCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StupidSlowCRX &raquo;</TD></TR><TR><TD CLASS="quote">fo the money spent to boost the c1.... why not setup the c5 with an all motor layout? </TD></TR></TABLE>
the c5 is a great motor stock but if you looking for speed i would boost the c1. IMO you would be happier with a boosted c1 over the N/A c5!
Old Jul 12, 2004 | 07:35 AM
DC2R714's Avatar
Turbo biatch! haha Philly Crew Expo 4 Tshirt design
Old Jul 12, 2004 | 07:53 AM
RTW DC2R's Avatar
F all motor! see sig
Old Jul 12, 2004 | 07:54 AM
vtec.dc2's Avatar
Default Re: (DAsix)
Turbo Lag &gt; NA Lag
Old Jul 12, 2004 | 08:09 AM
Rory Breaker's Avatar
Default Re: (vtec.dc2)
Turbo Lag = not in anyones vocabulary who actually is turbo'd properly
No contest...
Old Jul 12, 2004 | 08:12 AM
PM-Performance's Avatar
Default Re: (newgsrdriver)
this is a retarded debate.
Turbo all the way.
btw. . . .
Old Jul 12, 2004 | 08:18 AM
RobbieG35's Avatar
12 Years Strong
Default Re: (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
I agree, BOOST it!
Old Jul 12, 2004 | 08:25 AM
DAsix's Avatar
NA Lag?????
Old Jul 12, 2004 | 08:33 AM
Default Re: (DAsix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAsix &raquo;</TD></TR><TR><TD CLASS="quote">NA Lag????? </TD></TR></TABLE>
yes NA lagging in power.
Old Jul 12, 2004 | 08:44 AM
RobbieG35's Avatar
12 Years Strong
yes NA lagging in power. </TD></TR></TABLE>
itr206 bout to start a riot
Old Jul 12, 2004 | 08:55 AM
vtec.dc2's Avatar
Default Re: (DAsix)
do you get same response when you step on gas at 4K rpm vs 7K rpm?
so can you say.. your car lags response at low rpm?
i may have to wait for millisecond for my **** to spool to 10psi while at low rpm, but i still make power at 3-4psi, and i'm at 3-4psi as soon as i step on throttle matching whatever you make n/a at lower rpm
Old Jul 12, 2004 | 09:04 AM
even with turbo lag, its not a big deal . by the time it does spool can you say . . . buh bye. trust me even if the NA car got the jump the Turbo car would make up real quick.
Old Jul 12, 2004 | 09:07 AM
DC2R714's Avatar
Even if you are going to road race. A proper turbo setup will kickass. As long as you get a turbo with the kind of powerband you want it will work. An 18G torque curve is so linear it looks like an N/A powerband with alot more power and spools almost instantly.
Old Jul 12, 2004 | 09:11 AM
Default Re: (DC2R714)
its all about the way its set up and tuned. not everyone has needs for a t3/t4, or straight t3, or an 18g. depends on what you want the car to do . people dont understand that most of the time when they get into turbo
