Does cold air AEM help that much >? Or is the hot air better on some setups ?
Old Nov 21, 2001 | 07:56 PM
SpoonFed's Avatar
Default Does cold air AEM help that much >? Or is the hot air better on some setups ?
Why do some people choose the hot air intake vs. the cold setup...knowing that the cold will get more results...?
Old Nov 21, 2001 | 08:00 PM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
Default Re: Does cold air AEM help that much >? Or is the hot air better on some setups ? (spoonfed)
I've heard that short-ram (what you call hot-air) are better on top end, once the car is really moving, because the air rushing into the engine bay is pretty chilly already and it has less distance to travel than in a CAI like AEM or Comptech.
Old Nov 22, 2001 | 12:02 AM
Tommy_Gunns's Avatar
Default Re: Does cold air AEM help that much >? Or is the hot air better on some setups ? (Ross1013)
Comptech Ice box has approximately the same length of intake tubing as stock...it gets its cold air by plumbing the "resonator" to collect air (funnelling ram air) from the front of the car.
Old Nov 22, 2001 | 12:54 AM
gmsu00's Avatar
New User
I have iceman ... when I had DC sports short air intake...I lost to RSX type-S. I found out that DC one is worse than stock one. So I bought iceman ..I won.
I don't know about top end is better with short intake but...I think our engine gets very hot if we race couple times whatever...and it will be very hot under the hood...I guess...
or short air intake has better response...I'm not really sure about all this but a...my car got faster after installing iceman which is CAI system.
Old Nov 22, 2001 | 05:19 AM
SoCal ITR's Avatar
Default Re: Does cold air AEM help that much >? Or is the hot air better on some setups ? (gmsu00)
It was my impression that cold air is always better. When they say that top end might be helped out with a short ram, it's my guess that once you are going fast, the air under the hood cools down, and because there is less tubing to pass through on the short ram, it flows better, just a guess though.
Old Nov 22, 2001 | 05:36 AM
BoM's Avatar
BoM
Default Re: Does cold air AEM help that much >? Or is the hot air better on some setups ? (SoCal ITR)
AEM is good, but when ur revving pass 8k , short ram will outperform it
due to the shorter distance...velocity is way faster then...
Old Nov 22, 2001 | 05:44 AM
JohnnyBoy's Avatar
Default Re: Does cold air AEM help that much >? Or is the hot air better on some setups ? (BoM)
The colder the air the better it is for the engine.
james77bmx
Feb 13, 2011 06:08 PM
BSQ
Oct 18, 2007 04:43 PM
dohc_profile
Jan 14, 2006 01:15 PM
BSQ
Nov 8, 2001 11:57 AM
IGGY
Jul 14, 2001 10:37 PM
