please help.no power at fuel pump/ key on/ new main relay.
can someone help me figure this out... 91 crx si with no power at fuel pump- tested... put in new main relay, have spark, but no power to fuel pump...i'm stumped please help
ok does your ecu check engine light go off after u turn the key on or does it stay on for more than a few seconds? If it doesn't stay on check your ground on the thermostat housing if it does stay on check your alt fuse under the dash and you main fuse in the box in the engine bay.
wtfisvtec??
38
Jun 30, 2024 05:13 PM
jaerikd
22
Dec 20, 2018 11:51 AM
electron_si
Feb 18, 2008 08:17 AM
