oil in a bad place?
did u do an oil change recently? maybe you over-filled. the oil is coming from the the hose where the intake is connecting to the vlave cover. check your oil level, get some cabeurator cleaner and spray your throttle body a little. clean it up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GUNNER666 »</TD></TR><TR><TD CLASS="quote">just checked and its overfilled
is having too much oil a bad thing?</TD></TR></TABLE>
yes getting oil into the combustion chamber is BAD!!!!!!!!
take off the intake and while the car is on spray some cabeurator cleaner into the throttle body, while turning the throttle a little.
after that should be no harm
Yes, it's bad to overfill the crankcase. Remove the specific amount of fluid you overfilled with. Overfilling the crankcase can lead to MAJOR motor malfunction such as bent rods, etc.
Always check the level before you just dump motor oil in your crankcase. Drop in 3 quarts, add from there while continuously checking the level.
The oil in your intake pipe is a form of "blow-by". Jeep 4.0 motors are notorious for this due to the valvecover breather tube getting gunked by dried oil. This is a form of it.
My focus was notorious for doing this also it literally gunked up my AEM intake after a while and it wasnt overfilled, it just let oil in through the PCV pipe on a regular basis, what a POS dont ever buy ford, Im glad I bought a honda
cilvia
Jan 10, 2008 12:38 AM
rayzian
16
Aug 17, 2007 06:48 AM
