SAFC install help
Old Jul 11, 2004 | 06:07 AM
sleepin91teg's Avatar
Default SAFC install help
HELP...
So i got my used safc and im installing it...i have a 91 integra, pr4 ecu...i went to apexi-usa.com and looked at the manual...i hooked up 5 wires...the ones they said...ill post wich ones if you need to know them...my car is in no condtion to start yet (head is torn off) but i dont think this has anything to do with it...i cant get the SAFC to stay on, i have to hold the buttons down, and then its useless to use...when i turn my ignition ON the SAFC should come on i beleive...HELP HELP HELP
Old Jul 11, 2004 | 06:18 AM
skunkintegra's Avatar
Default Re: SAFC install help (sleepin91teg)
i would have to say TRIPLE check your connections.
If it still doesn't initialize when you turn the key, i'd be thinking the used safc is junk
Old Jul 11, 2004 | 06:20 AM
Default Re: SAFC install help (skunkintegra)
I will triple check everything...but when i had it right when i got it...i just put the red wire on the positive battery termina, and black wire on the negative battery terminal...and i still had to hold the buttons down get it to turn on...so i think that would illiminate my connections not being so great...
Old Jul 11, 2004 | 06:25 AM
SAFC version 1 im assuming?(not SAFC II)
so... diagram H-1 here?
Old Jul 11, 2004 | 07:08 AM
Ok i have all of those 5 wires hooked up, from diagram H1...Anyother ideas? Are these the only 5 wires i hook up? there are 10 total wires in the harness...
Old Jul 11, 2004 | 08:21 AM
slo2kgsr's Avatar
only 2 possible problems in my mind loose power connection or safc is botched up internally. Get a meter and see if you have pwer to the safc after it has turned off.
Old Jul 11, 2004 | 06:08 PM
Default Re: SAFC install help (tegraLS97)
I got it...There is 2 ground, black and brown wire...i only had the black hooked up!!! Thanx
bcintron95
Audio / Security / Video
Sep 13, 2013 06:07 AM
lowlifechris
Jun 19, 2008 09:35 AM
egcivic
Nov 24, 2006 02:53 AM
gtowni3
Mar 14, 2005 05:59 AM
acman1
Mar 30, 2003 12:48 PM
