brakes wtf
ok heres the problem today i was just ridin when my brake pedal just got stiff.. It still had a little stop but not alot i think it might be the booster. And when i push the pedal all the way down air sounds like its leaking out into the car.. and the idle just jumps around like skipping sounding (if you know what i mean)
thanks
thanks
it shoulden be to hard if u got the a stock motor in there but with a swap it can get tricky
and well if u can't get a OEM replacement I got one that I replaced w/ a ITR instead have the M/C too
but it is ur booster either a leak or shot
and yeah u lucky ur brakes didn't go out and slamm into someone
my friend did that but he knew about it and waited a bit to long to change or replace it
Moran huh???
Moran huh???
test your booster, just pump your brakes 5 times wit the car off ,then turn the car on if the pedal drops a lil it meand the booster is working if its still stiff then its your booster
Randysi
26
Jul 26, 2012 03:28 AM
