Transmission Disassembly Question
Old Jul 10, 2004 | 04:18 PM
TorganFM.'s Avatar
Default Transmission Disassembly Question
Foreword: I have searched.
I have a transmission out of a 95 EX in my shed right now. I am currently attempting to open it up and see if the gears are all torn to hell (the car it came from was totalled after running through the woods, leaving the suspension pushed back 6 inches). I have taken off all of the 12mm bolts and such from around the housing with the oil drain plugs, but something is still holding the thing on there. The only thing left on it is the VSS. Should I remove this or should the housing come off with it still on? Also the housing has started to come off (the seal has been broken) but I just can't get it off more than 1mm. Thanks in advance.
Old Jul 10, 2004 | 04:59 PM
TorganFM.'s Avatar
Default Re: Transmission Disassembly Question (DanW)
ttt to the top or tight twatted teenies...
Old Jul 10, 2004 | 05:08 PM
B2FiNiTY's Avatar
Snap ring?
Old Jul 10, 2004 | 05:10 PM
TorganFM.'s Avatar
Default Re: Transmission Disassembly Question (B2FiNiTY)
What's this?
Old Jul 10, 2004 | 05:13 PM
Ricey McRicerton's Avatar
There are quite a few things left on there. I suggest getting a Helms manual if you're trying to tear down a tranny. Also, check up on the thread by BauleyCivic about replacing your input shaft bearing.
You will need to remove 3 small bolts with some ***** and springs in them along with the snap ring under the 32mm bolt on the end of the tranny.
Seriously, before you do this, you either need to read up on that thread by Dusin or get a helms, or probally both. It'll save you a helluva lot of headaches.
Old Jul 10, 2004 | 05:15 PM
TorganFM.'s Avatar
Default Re: Transmission Disassembly Question (Ricey McRicerton)
Which end of the transmission is this 32mm bolt on? The outside or where the flywheel would be? I have read Bauley's threads about seal replacements. I think I see this snap ring.
Old Jul 10, 2004 | 05:17 PM
The "bolt" which is actually more of a plug is going to be removed with a 1/4 or 1/2 inch drive ratchet. It's on the end of the tranny opposite the flywheel and actually locks around either the mainshaft or countershaft (can't remember, wanna say countershaft). Once you get that out you'll need snapring pliers and some patience to get the whole thing off. It took me and a friend the better part of 10 minutes of messing with it to get it off. Before you get to that point just take everything you see on the tranny out. Label it, mark on the tranny casing if need be where it goes, do what you need to do to get it all back in. The clutch housing and tranny housing should seperate 1/2 inch or so before you even need to get out the snapring pliers and get that though.
Old Jul 10, 2004 | 05:28 PM
snowman0520's Avatar
heres a link to the manual. make sure u dont get teh auto and manual trans mixed up. its hard to find pages on the link buts its betterthan nada
*removed by admin*
Old Jul 10, 2004 | 06:14 PM
TorganFM.'s Avatar
Default Re: (snowman0520)
Been there, done that. Got to the automatic section and my comp locked up. PDF's are lame enough, but 5000 pages of them is just too much.
Old Jul 10, 2004 | 06:16 PM
BauleyCivic's Avatar
Risky Business
Default Re: (DanW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DanW &raquo;</TD></TR><TR><TD CLASS="quote">Been there, done that. Got to the automatic section and my comp locked up. PDF's are lame enough, but 5000 pages of them is just too much.</TD></TR></TABLE>
Then go buy the real manual
Old Jul 11, 2004 | 09:24 AM
TorganFM.'s Avatar
Default Re: (BauleyCivic)
Update: I got the housing off and everything looks very good, so I'll just clean it and put it back together and toss it into my car. There is only one problem... when I took the housing off I noticed one of the gears was off. I'm fairly certain that it goes into the hole right next to it with the fork over it, but I'm not sure which end is up and which end is down.
edit1:
http://dw.thenewfrontier.net/pics/DSC00328.JPG
http://dw.thenewfrontier.net/pics/DSC00329.JPG
http://dw.thenewfrontier.net/pics/DSC00330.JPG
edit2: Also what should I use to seal the transmission back up? HondaBond or sillicone stuff?
Old Jul 11, 2004 | 09:49 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: (DanW)
thats just the reverse idler gear. Make sure you get it properly installed with the selector fork also.
and use a thin coat of Hondabond around the case. Use new crush washers for the spring and ball seats, and Hondabond on the snap ring plug.
Bench shift the tranny through all gears and spin the main shaft and make sure the change of speed in the diff is proportional
Old Jul 11, 2004 | 10:00 AM
TorganFM.'s Avatar
Default Re: (Emerika)
That's odd, I didn't find any bolts with a spring and ball. On the inside area with the input shaft I did find however a bolt with a spring on it. Does that reverse idler gear just go where that hole is in the fork thingy? I put in there but the idler gear was making contact with the really big gear just to the left of the hole in pics 329 and 330.
Old Jul 11, 2004 | 10:11 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: (DanW)
well, you probably didn't pull the spring and ***** out, which means they got lost somewhere. There should be I believe 3 of them. And the ***** make contact with the indent on the shift forks...
Old Jul 11, 2004 | 10:25 AM
TorganFM.'s Avatar
Are they lost somewhere in the transmission? I ask this because I unscrewed everything on the outside and only found the spring next to the input shaft. The only ***** I see in there are the ones in the bearings. I have that reverse idler gear back in place but it just doesn't seem like it goes there.
Old Jul 11, 2004 | 11:22 AM
TorganFM.'s Avatar
Default Re: (DanW)
Bump, this spring ball stuff is worrying
Old Jul 11, 2004 | 02:26 PM
TorganFM.'s Avatar
Default Re: (DanW)
After looking at a diagram of a D transmission the only spring ***** are in the transmission, under the final drive and such.
Old Jul 11, 2004 | 07:35 PM
B2FiNiTY's Avatar
Default Re: (DanW)
The reverse idler gear WILL go in the wrong way. Make sure it is in the right way otherwise you won't be able to bolt it all up. The right way is with the hole upwards so that a bolt can go through.
Old Jul 11, 2004 | 08:38 PM
cxSHOE's Avatar
check your pm. you will find something that will help with all your repairs.. just follow the book. go to chapter 13..its not hard.
Old Jul 12, 2004 | 05:07 AM
EE_Chris's Avatar
Default Re: Transmission Disassembly Question (cxSHOE)
1995 Ex:
1996 Ex:
It looks as though the shift detent bolt/spring is internal to the 5th gen Ex (#13, 8) vs external like the 6th gens (#10, 9, 23).
Old Jul 12, 2004 | 05:20 AM
Arbadacarba's Avatar
What was this that would help him with the repairs?
Just curious, as I've done this myself recently.
Arbadacarba
Old Jul 14, 2004 | 04:08 PM
TorganFM.'s Avatar
Default Re: Transmission Disassembly Question (Arbadacarba)
I'm trying to put it back together now, but I can get it to within 2mm of closing and it just stops going. The snap-ring is very close to being on. Oh well round 2 tomorrow.
Old Jul 14, 2004 | 05:54 PM
B2FiNiTY's Avatar
You have to have the snap ring expanded while closing the case. It will snap on and the case should close.
Old Jul 14, 2004 | 06:11 PM
Sliced Beard's Avatar
https://honda-tech.com/zerothread?id=795700
best tranny write up so far on h-t that I have seen
Old Jul 14, 2004 | 06:25 PM
B2FiNiTY's Avatar
Default Re: Transmission Disassembly Question (dirtyd463)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtyd463 &raquo;</TD></TR><TR><TD CLASS="quote"> https://honda-tech.com/zerothread?id=795700
best tranny write up so far on h-t that I have seen </TD></TR></TABLE>
helped me a ton!
