Code 6, Code 8, Reving limit at 3200
Old Jul 10, 2004 | 01:29 PM
T--Rex's Avatar
Default Code 6, Code 8, Reving limit at 3200
Ok, I have the new ECU wired up but the car only revs to about 3200 rpms. It does drive, but it throws a code 6 and code 8, the water temp sensor works good - it and the wires go to the ECU good. Could it be an ecu problem? If so do you know if there is a way to get the ECU checked with out buying a new one. (Kinda low on cash).
Haven't checked code 8 yet.
Old Jul 10, 2004 | 02:15 PM
Die-Laughing's Avatar
Default Re: Code 6, Code 8, Reving limit at 3200 (Matrix_Zero)
i would try to borrow one of your friends ecu's and see if that does anything.
also, go over your wiring several times before calling it "ok".
i've made that mistake before
ilikejesus
Jul 2, 2007 06:10 PM
T--Rex
Jul 10, 2004 02:02 PM
HondaCutie90
Feb 25, 2002 09:43 AM
