squeak when i disengage clutch.. clutch going?
Old Jul 10, 2004 | 11:58 AM
ibe2fly's Avatar
Default squeak when i disengage clutch.. clutch going?
hey guys quick question for a couple weeks now i've been hearing a squeaking noise when i press down my clutch not loud but defintely noticable with the windows down and music off .... is the clutch going .. what could this be? hopefully just gotta throw some wd-40 on something lol .... anyway i bled my clutch a couple weeks ago i lost all pressure on the clutch pedal .. since then it seemsfine but i still hear that squeaking ... any ideas? thanx
Old Jul 10, 2004 | 12:00 PM
SiYouLater's Avatar
Default Re: squeak when i disengage clutch.. clutch going? (ibe2fly)
Check your slave cylinder and master cylinder for leaks. And try to grease the slave cylinder joint thing.
Old Jul 10, 2004 | 12:02 PM
Ricey McRicerton's Avatar
Default Re: squeak when i disengage clutch.. clutch going? (99FBPSi)
Does it on almost every civic I've been in. Nothing to worry about.
Old Jul 10, 2004 | 12:03 PM
ibe2fly's Avatar
thanx ill do that today umm ? though .. what kinda grease to use ... DON" SHOOT ME!!! ... lol im a newb anything in particular or just goto CarQuest n ask them there?
Old Jul 10, 2004 | 12:05 PM
ibe2fly's Avatar
Default Re: squeak when i disengage clutch.. clutch going? (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">Does it on almost every civic I've been in. Nothing to worry about. </TD></TR></TABLE>
o ok thanx cuz i was reading some posts just lookin around and i saw some dude said he heard a noise from his clutch n had to changed but he had other problems as well thx
Old Jul 10, 2004 | 03:26 PM
EK45VTi's Avatar
Throwout bearing is not lubed properly or grease has washed off...
Do not try to regrease the throwout bearing cos you will make some serious problems for yourself...
Just leave it be... every Civic does that...
Deemeetree's Avatar
Electrician
Old Jul 10, 2004 | 03:31 PM
Tad's Avatar
Tad
could be the spring on the clutch pedal,
try greasing that.
if it is the tob you cant do much without replaceing it.
but the TOB makes noise when the clutch is NOT engaged.
TypeR324
Honda S2000
Sep 8, 2009 08:42 AM
Felt.2
Aug 13, 2006 03:47 PM
akteamster
10
Aug 13, 2004 04:13 PM
civcexcoupeblack
Aug 25, 2003 07:21 PM
92civeg
Jun 29, 2003 12:49 PM
