All those people with reare drum........how do i adjust them
Old Jul 10, 2004 | 09:10 AM
B HATCH's Avatar
Default All those people with reare drum........how do i adjust them
I need to adjust my rear drums..........does anyone know how to do this.?
Old Jul 10, 2004 | 09:17 AM
spyderracing's Avatar
Default Re: All those people with reare drum........how do i adjust them (B HATCH)
maybe a little more info? adjust them how?
Old Jul 10, 2004 | 09:31 AM
miahmouse's Avatar
take the drum off and towards the top of the assembly between the shoes there's a bar with threads on it, spin in to desired level(just before you can't get the drum back on..."slight drag"). it's pretty much the only thing you can adjust... other than the cables themselves....
Old Jul 10, 2004 | 09:43 AM
hatchi's Avatar
why would you need to adjust them?? The rear drums have built in adjusting mechanisms. unless you just changed your rear shoes. inside the drum there is a starwheel that can be turned one way to expand and locks the other way to loosen. on the back there is a hole that you will need to get a flathead or adjusting spoon to get to it. Of course you will need to have your drums in there.
Old Jul 10, 2004 | 10:58 AM
fathergoose's Avatar
that mechanism doesnt work at all, you need to adjust manually turn the small dented wheel conterclockwise until you obtain the desired adjustment
Old Jul 10, 2004 | 11:22 AM
miahmouse's Avatar
Default Re: (fathergoose)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fathergoose &raquo;</TD></TR><TR><TD CLASS="quote">that mechanism doesnt work at all, you need to adjust manually turn the small dented wheel conterclockwise until you obtain the desired adjustment</TD></TR></TABLE>
that's what we both just said.... turn the little wheel thing
B HATCH's Avatar
thank you
SLATER97EX
May 7, 2012 03:50 AM
street_ride14
Paint and Body
Oct 2, 2009 08:02 PM
goldegg
Feb 14, 2007 09:46 AM
atg1290
Jul 19, 2006 06:18 PM
asmallsol
Apr 13, 2004 09:32 AM
