Gsr cluster in Eg write up???
Old Jul 10, 2004 | 07:35 AM
onefstek's Avatar
Default Gsr cluster in Eg write up??? New pics
well I kind of made a write up for putting a gsr cluster in the eg's, don't know if anyone is interested. This works well for people that have the dx eg's since they don't have a tach and want to upgrade to a gsr cluster. Let me know if anyone might be interested and ill post it. 98ctr
Update:
Parts needed:
-Gsr cluster from any Integra Gsr 96-00
-Gsr plugs for the cluster (from your local junk yard)
(the pins from the 5g civic will not work on the gsr plugs so you need the two plugs and about 4" of the wires so you can cut and solder to the civic harness)
-Solder and solder gun, I will encourage to solder and shink tube all the connections. Do it right the first time and you wont regret it later.
-Dremmel tool. You will need to cut the top of the gsr cluster to be able to fit back your civic panel back into place.
-Two zip ties or you can fabricate two small brackets to screw the gsr cluster in the civic mounting holes (gsr cluster is a bit longer so the zip ties works grate)
Steps:
1. Remove civic panel
2. Remove civic cluster
3. Cut and solder wires ONE AT A TIME so you don't get confused in all the mess
4. Trim top mounting bracket on the gsr cluster
5. Use tow zip ties to place gsr cluster in place of the civic cluster
6. Trim civic panel on the left and right side so it clears the gsr cluster
7. Put back the panel and enjoy your new DIY mod.
Here is the wiring:
integra 13 pin plug to civic plug
1a--blu to 8a--blu
2a--grn/org to 5b--grn/org
3a--yel/red to 6a--yel/red
4a not used
5a--wht/blu to 5a--wht/blu
6a not used
7a--yel/grn to 7b--yel/grn
8a--blk to 6b--blk
9a not used
10a--yel to 8b--yel
11a not used
12a not used
13a not used
integra 16 pin plug to civic plug
1b--grn/red to 2b--grn/red
2b--red/grn to 1b--red/grn
3b--grn/yel to 3a--grn/yel
4b--grn/blu to 4a--grn/blu
5b not used
6b--blk/yel to 10a--blk/yel
7b--red/blk to 11a--red/blk
8b--red to 12a--red
9b not used
10b--grn to 9b--grn
11b--org to 2a--yel/blu
12b not used
13b not used
14b--yel/wht to 1a--yel/wht
15b not used
16b--red/blu to 10b--blu/wht
Good luck. 98ctr
http://www.newbieforces.com/files/IM001001.jpg
http://www.newbieforces.com/files/IM000999.jpg
Modified by 98ctr at 2:26 AM 8/1/2004
Old Jul 10, 2004 | 07:47 AM
onefstek's Avatar
Default Re: Gsr cluster in Eg write up??? (98ctr)
oops wrong forum, sorry can it be moved to EG/EK please.
Old Jul 10, 2004 | 02:06 PM
Ajax's Avatar
I'm interested, I'm looking for a GSR cluster right now for my 92 CX.
Old Jul 10, 2004 | 02:10 PM
snowman0520's Avatar
def interested
Old Jul 10, 2004 | 02:16 PM
cnyej1's Avatar
Default Re: Gsr cluster in Eg write up??? (Ajax)
Post up a good diy thread that would be helpful!
Old Jul 10, 2004 | 02:51 PM
ch4nq's Avatar
Default Re: Gsr cluster in Eg write up??? (cnyej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cnyej1 &raquo;</TD></TR><TR><TD CLASS="quote">Post up a good diy thread that would be helpful!</TD></TR></TABLE>
Old Jul 10, 2004 | 03:45 PM
nwdave's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98ctr &raquo;</TD></TR><TR><TD CLASS="quote">Let me know if anyone might be interested and ill post it.</TD></TR></TABLE>
I'm interested in seeing it
Old Jul 10, 2004 | 04:36 PM
MI KENT's Avatar
Default Re: Gsr cluster in Eg write up??? (nw.dave)
i'm interested.
Kent
Old Jul 10, 2004 | 04:48 PM
onefstek's Avatar
Default Re: Gsr cluster in Eg write up??? (MI KENT)
teg blue l/h side plug (13 pins) civic l/h side grey plug (12 pins) teg civic
1. blu tach signal 1. yel/wht fuel gauge 1a--blu 8a--blu
2. grn/org check engine indicator 2. yel/blu vehicle speed sensor 2a--grn/org 5b--grn/org
3. yel/red oil pressure switch 3. grn/yel right turn 3a--yel/red 6a--yel/red
4. NOT USED 4. grn/blu left turn 4a
5. wht/blu charge indicator 5. wht/blu charge indicator 5a--wht/blu 5a--wht/blu
6. NOT USED 6. yel/red oil pressure switch 6a
7. yel/grn coolant temp 7. NOT USED 7a--yel/grn 7b--yel/grn
8. blk ground 8. blu tach signal 8a--blk 6b--blk
9. red/blu cruise (if you have cruise) 9. NOT USED 9a
10. yel hot 10. blk/yel power 10a--yel 8b--yel
11. NOT USED 11. red/blk power 11a
12. pink maintenance (not used) 12. red power 12a
13. NOT USED 13a
teg r/h side blue plug (16 pins) civic r/h side grey plug (10 pins) teg civic
1. grn/red e.brake signal 1. red/grn high beam indicator 1b--grn/red 2b--grn/red
2. red/grn high beam 2. grn/red e brake signal 2b--red/grn 1b--red/grn
3. grn/yel right turn 3. NOT USED 3b--grn/yel 3a--grn/yel
4. grn/blu left turn 4. NOT USED 4b--grn/blu 4a--grn/blu
5. NOT USED 5. grn/org check engine indicator 5b
6. blk/yel power 6. blk ground 6b--blk/yel 10a--blk/yel
7. red/blk power 7. yel/grn coolant temp 7b--red/blk 11a--red/blk
8. red power 8. yel hot 8b--red 12a--red
9. blu/red abs (not used) 9. grn trunk switch 9b
10. grn trunk switch 10. blu/wht seat belt 10b--grn 9b--grn
11. org vehicle speed sensor 11b--rg 2a--yel/blu
12. NOT USED 12b
13. blu/wht low fuel 13b
14. yel/wht fuel gauge 14b--yel/wht 1a--yel/wht
15. lt grn/red door switch 15b
16. red/blu seat belt 16b--red/blu 10b--blu/wht
Old Jul 10, 2004 | 04:53 PM
onefstek's Avatar
its hard to tell what goes where, but they are in numerical order. All the wires colors from the integra match the civic except a couple of them on the second plug. 98ctr
Old Jul 10, 2004 | 04:54 PM
onefstek's Avatar
Default Re: (98ctr)
1. blu tach signal
4. NOT USED
6. NOT USED
8. blk ground
10. yel hot
11. NOT USED
13. NOT USED
5. NOT USED
6. blk/yel power
7. red/blk power
8. red power
12. NOT USED
Old Jul 10, 2004 | 04:55 PM
onefstek's Avatar
Default Re: (98ctr)
7. NOT USED
8. blu tach signal
9. NOT USED
10. blk/yel power
11. red/blk power
12. red power
3. NOT USED
4. NOT USED
6. blk ground
8. yel hot
9. grn trunk switch
onefstek's Avatar
Default Re: (98ctr)
integra plug to civic plug
1a--blu to 8a--blu
4a not used
6a not used
8a--blk to 6b--blk
9a not used
10a--yel to 8b--yel
11a not used
12a not used
13a not used
5b not used
8b--red to 12a--red
9b not used
10b--grn to 9b--grn
12b not used
13b not used
15b not used
Old Jul 10, 2004 | 08:45 PM
slow eg's Avatar
Default Re: (98ctr)
wow very koo to noe this stuff...i got an cx wit not tach eheh
Old Jul 11, 2004 | 08:41 AM
onefstek's Avatar
Default Re: (slow eg)
Parts needed:
Steps:
Good luck. 98ctr
Old Jul 11, 2004 | 08:49 AM
trooper0641's Avatar
Default Re: (98ctr)
dont do it...its not worth the hassle that **** is a bitch i just gave up on it.
the hardest part of that swap would be to find the cluster plugs...and the trimming to actually make it LOOK GOOD. I have only seen very few...1 or 2 that LOOKS OKAY.
Old Jul 11, 2004 | 10:08 AM
onefstek's Avatar
Default Re: (trooper0641)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 &raquo;</TD></TR><TR><TD CLASS="quote">dont do it...its not worth the hassle that **** is a bitch i just gave up on it.
the hardest part of that swap would be to find the cluster plugs...and the trimming to actually make it LOOK GOOD. I have only seen very few...1 or 2 that LOOKS OKAY.</TD></TR></TABLE>
Well that is your oppinion, I just did one on my friends dad civic and it looks decent. It took me about 1 hr. The plugs you can get from the junk yard, all you have to do is find an integra and tell them you need the plugs, or tell them you need something else on the car.(hint)
Old Jul 11, 2004 | 10:50 AM
murtnabila's Avatar
Default Re: (98ctr)
great thread! I was looking for one of these a while back and never found it.
Old Jul 11, 2004 | 10:58 AM
Default Re: (98ctr)
Well that is your oppinion, I just did one on my friends dad civic and it looks decent. It took me about 1 hr. The plugs you can get from the junk yard, all you have to do is find an integra and tell them you need the plugs, or tell them you need something else on the car.(hint) </TD></TR></TABLE>
its impossible to find a integra or even a civic in california's junkyards. dont give me wrong gsr cluster is pretty cool but its a pain the get the plugs and trimming the edges perfect.
Old Jul 11, 2004 | 11:20 AM
onefstek's Avatar
well its here if anyone wants it. 98ctr
Old Jul 11, 2004 | 11:36 AM
nwdave's Avatar
Default Re: (98ctr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98ctr &raquo;</TD></TR><TR><TD CLASS="quote">well its here if anyone wants it. 98ctr
Thanks for the info
Old Jul 11, 2004 | 12:06 PM
onefstek's Avatar
it would be nice if this could be stickied. that way its allways on top. 98ctr
Old Jul 11, 2004 | 01:23 PM
murtnabila's Avatar
Default Re: (98ctr)
not to mention this is a great thread for people doin gsr dash in eg!
Old Jul 11, 2004 | 02:21 PM
onefstek's Avatar
Default Re: (murtnabila)
tru that, I didn't think of that.
Old Jul 13, 2004 | 07:08 PM
onefstek's Avatar
Default Re: (98ctr)
