Clutch is too light! And no its not a bleeding problem...
Old Jul 9, 2004 | 11:17 PM
trooper0641's Avatar
Default Clutch is too light! And no its not a bleeding problem...
I have a brand new exedy organic clutch with a prolite flywheel and for some odd reason it still feels like my old worn clutch? what the hell...bled this **** like crazy. there is one thing...i am noticing that my slave cylinder seems to drain faster than the average cylinder. ive checked for any sign of leaks but there arent any...
and no just cus its a pretty much stock clutch...trust me this **** has to have more pressure than what i have. its not sagging...but its light and its not grippin' at all.
Old Jul 9, 2004 | 11:29 PM
Uncle Ben's Avatar
Default Re: Clutch is too light! And no its not a bleeding problem... (trooper0641)
Damn man, I gotta help you with everything!?! . Just messin...did you replace your throw out bearing with the clutch? Hows the fork look? I blead mine a couple times before it felt right. Whada know...just changed mine also...weird. BTW, how's the manifold commin?
Old Jul 9, 2004 | 11:48 PM
Default Re: Clutch is too light! And no its not a bleeding problem... (Uncle Ben)
the manifold is fixed! yay! i swear to god i gained like 20 whp out of it thanks for your help uncle ben your the best!
Old Jul 9, 2004 | 11:49 PM
but yes i replaced the throw out bearing...i think imma just replace my slave cylinder with a new one and call it a day.
Old Jul 9, 2004 | 11:50 PM
is there any way to "adjust" the clutch on hydro trannies?
Old Jul 9, 2004 | 11:51 PM
Uncle Ben's Avatar
What I like to hear
Old Jul 9, 2004 | 11:53 PM
Uncle Ben's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 &raquo;</TD></TR><TR><TD CLASS="quote">is there any way to "adjust" the clutch on hydro trannies?</TD></TR></TABLE>
Hmm, not to sure on that one...I always thought they "automatically" adjusted themselves...I just blead the mess out of mine .
Old Jul 9, 2004 | 11:55 PM
blah i see...hmm sux for me i guess ill just try replacing the slave cylinder...cus i think it maybe losing pressure from that **** cus the brake fluid runs out pretty fast. not FAST but faster than the average civic
Old Jul 10, 2004 | 12:03 AM
Uncle Ben's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 &raquo;</TD></TR><TR><TD CLASS="quote"> not FAST but faster than the average civic</TD></TR></TABLE>
^ Just that made me laugh ^
Old Jul 10, 2004 | 12:52 AM
is there any way of the slave cylinder going bad?
Old Jul 10, 2004 | 11:19 AM
EK45VTi's Avatar
Yes, there IS a way that your slave cylinder can go bad...
And NO... there is NO WAY YOU CAN ADJUST HYDRO CLUTCH...
I tried it with some bleeding and pushing the fork more backwards and it was like I adjusted for 3 miles... after that it all went like it has been before...
Where are those NICE cable-days??? no squeeling, no fluids, no hassle, no leaks... just cable and whoooooooooaaaaaaa
Old Jul 10, 2004 | 11:41 AM
Default Re: Clutch is too light! And no its not a bleeding problem... (KKVTi)
mother ****** i guess imma just replace my slave and call it a day
Old Jul 10, 2004 | 11:53 AM
Evs-One's Avatar
Solbros Owns Me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KKVTi &raquo;</TD></TR><TR><TD CLASS="quote">
I</TD></TR></TABLE>
you say this with such certainty.....which I find rather interesting.
As you can adjust the pedal freeplay on our hydro clutches. YOu should NEVER lose fluid from your resevoir, or you have a problem/leak somewhere...simple as that
Old Jul 10, 2004 | 12:14 PM
senpai's Avatar
Default Re: Clutch is too light! And no its not a bleeding problem... (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika &raquo;</TD></TR><TR><TD CLASS="quote">
As you can adjust the pedal freeplay on our hydro clutches. YOu should NEVER lose fluid from your resevoir, or you have a problem/leak somewhere...simple as that</TD></TR></TABLE>
Damn, beat me to it. You can adjust the clutch 'indirectly' at the base of the clutch pedal where it meets the firewall.
Have someone step on the clutch while you check the side-side motion of the shifter fork that holds the thorwout bearing.
Old Jul 10, 2004 | 12:27 PM
SLowCrx's Avatar
Check your Clutch Master cylinder to. Just reach up under the dash where the clutch pedal is and see if the master cylinder is leaking onto the firewall anywhere or around the shaft that connects to the pedal.
Old Jul 10, 2004 | 12:28 PM
SLowCrx's Avatar
Might want to make sure none of our hoses are leaking either.
Old Jul 10, 2004 | 12:53 PM
Default Re: Clutch is too light! And no its not a bleeding problem... (SLowCrx)
alrighty thanks guys ill loook into it
Old Jul 10, 2004 | 03:34 PM
EK45VTi's Avatar
Default Re: Clutch is too light! And no its not a bleeding problem... (maztur)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maztur &raquo;</TD></TR><TR><TD CLASS="quote">
Have someone step on the clutch while you check the side-side motion of the shifter fork that holds the thorwout bearing.</TD></TR></TABLE>
I was talking about the ACTUAL CLUTCH... not the pedal!!! But, I should have said about the pedal though... my mistake
Old Jul 13, 2004 | 03:53 PM
ttt has anybody ever had this problem?
Old Jul 14, 2004 | 04:26 AM
Old Jul 15, 2004 | 05:21 PM
123rfqweasd help me
Old Jul 15, 2004 | 05:45 PM
SolObsession's Avatar
When you bleed the clutch, pump like 3-4 times w/o going to the floor with the pedal. Then open the valve and push down about 1/2 way on the pedal. Do that maybe 8-10 times and it should be stiff.
Old Jul 15, 2004 | 09:26 PM
nocturnaldragon's Avatar
Theres an adjustment screw behind the clutch pedal on the rod that goes to the master cylinder that can be adjusted.
Old Jul 16, 2004 | 08:37 AM
Default Re: Clutch is too light! And no its not a bleeding problem... (nocternaldragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocternaldragon &raquo;</TD></TR><TR><TD CLASS="quote">Theres an adjustment screw behind the clutch pedal on the rod that goes to the master cylinder that can be adjusted.</TD></TR></TABLE>
there is? lol what am i suppose to do? find that bolt and just tighten it somehow?
Old Jul 16, 2004 | 02:28 PM
23qrwdfas32r1qwd
