Engine management for turbo application
Old Jul 9, 2004 | 10:19 PM
Nytmair's Avatar
Default Engine management for turbo application
Is it as simple as a VAFC and injectors, or should I look into uberdata or hondata. Boost level will be set at 7 psi, nothing major. It is this reason why I think my VAFC and 450cc injectors will in fact do the job and my Walbro 255 fuel pump
Does anybody have any advice, recommendations, etc?
Thanks, Mike
Modified by deathwish at 2:43 AM 7/10/2004
Old Jul 9, 2004 | 11:10 PM
ComputerJLT's Avatar
Default Re: Engine management for turbo application (deathwish)
uberdata
will cost less than $70 to get everything to get up and running (minus a wideband).
and unless you're a complete retard you can handle chipping the ecu and installing the injectors yourself.
get the 450s also; check out dsmtraders.com or dsmtrader.com dont remember. i bought my blue 450s for $20 shipped :-p they work like a champ!
and i'd get a good pump to go with those injectors also. shop around though and buy used to save money
Old Jul 10, 2004 | 08:45 AM
SpeedingHatch's Avatar
Default Re: Engine management for turbo application (ComputerJLT)
He said he has those injectors and fuel pump and VAFC already.
Old Jul 10, 2004 | 03:48 PM
Default Re: Engine management for turbo application (speedinghatch)
i'd still use uberdata and set teh afc to 0 and just tweak whatever when i felt like it
Old Jul 10, 2004 | 04:43 PM
GDM Z28's Avatar
use uberdata..i made 303whp/270wtq on a heatsoaked stock LS on 14 psi...
Old Jul 15, 2004 | 05:25 PM
Nytmair's Avatar
Default Re: Engine management for turbo application (civicflnum1)
where can I get uberdata? Is it compatable with p13 ECU's?
Old Jul 17, 2004 | 02:12 PM
Tex Blackwell's Avatar
ok, say when a person goes uberdata,
for instance i got a guy who wants to go turbo in his ls integra and i'm debating on what engine management to run him on
how much would it cost total to go uberdata, its a 95 integra, bone stock.
what all would i need and how much would it usually cost,
is there a web site that shows where to chip the ecu?
Old Jul 17, 2004 | 02:22 PM
beepy's Avatar
Default Re: Engine management for turbo application (mp3albums2k2)
I found this great how-to:
LINK
From what I gather you need an OBDI Honda ECU. Won't work with OBDII or non-Honda ECUs. (Though I'm sure it would be possible, if someone would spend a few thousand hours of research on other ECUs)
Old Jul 17, 2004 | 05:44 PM
TurboJesse
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deathwish &raquo;</TD></TR><TR><TD CLASS="quote">where can I get uberdata? Is it compatable with p13 ECU's?</TD></TR></TABLE>
no, you'd have to run a p28 or something.
Old Jul 17, 2004 | 07:58 PM
AirWaveGT's Avatar
Default Re: Engine management for turbo application (beepy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">I found this great how-to:
LINK
From what I gather you need an OBDI Honda ECU. Won't work with OBDII or non-Honda ECUs. (Though I'm sure it would be possible, if someone would spend a few thousand hours of research on other ECUs)</TD></TR></TABLE>
if your car is obd2 then all you have to do is buy an obd1 ecu and an obd2 to obd1 harness so you are converted to obd1 and everything will work just the same
Old Jul 17, 2004 | 09:03 PM
Default Re: Engine management for turbo application (AirWaveGT)
yea i'm using a p30 ecu
d!zZy
May 19, 2004 11:48 AM
DragInteg
Apr 3, 2003 11:49 AM
aemciv
Mar 31, 2003 12:37 PM
EF8_SiR
Nov 5, 2002 08:43 AM
