not starting
i have and 89 honda crx hf with a zc motor in it. the car starting fine till i broke my alarm remote. so i disconneted the alarm, and the car has problems starting. once in a while it starts with no problem, but it takes a while to do so, even sometimes jumping it. i heard that it might be a fuel relay switch under the dash causing this to act up. can someone plz help.
Don't know the climate where you are,BUT if it is hot,the main relay could very well be the problem.You can have someone resolder yours or buy a new one.If you live in a ok area,try leaving the windows crack open abit to keep the heat down inside the car,till you get it fixed.
