1997 integrea ls front and rear controll arms fit to an Ef?
Old Jul 9, 2004 | 08:13 PM
Natural Aspirations's Avatar
Default 1997 integrea ls front and rear controll arms fit to an Ef?
Does the 1997 integrea ls front and rear controll arms fit to an Ef? I would like to do a 4 wheel disk swap to my 91 dx and came by a dc2 setup for cheap.
Old Jul 9, 2004 | 08:25 PM
S9i1R's Avatar
Default Re: 1997 integrea ls front and rear controll arms fit to an Ef? (crixzc)
you don't need the control arms all you need are the trailing arm, rotor, calipers & cables. it's good to get a 40/40 proportioning valve when doing this conversion. do some searching around there is a bunch of really great info on here
Old Jul 10, 2004 | 03:13 PM
Default Re: 1997 integrea ls front and rear controll arms fit to an Ef? (S9i1R)
I was told on another board that the fronts would not work properly due to the fact that the 94-00 teg and the 92-00 civ has another 2 inches of travel in the front. it would throw the camber positive and would not be correctable.
Old Jul 10, 2004 | 06:48 PM
EL Vap133's Avatar
What you need are 90-93 Integra knuckles, or 90-91 EX Civic sedan knuckles to make those brakes fit on the front. Use your stock LCAs, front and rear, and use your stock fromt upper arms.
Old Jul 13, 2004 | 05:47 PM
Default Re: 1997 integrea ls front and rear controll arms fit to an Ef? (EL Vap133)
So if I can come by the 90-93 teg or 90-91 ex LCA's the dc-2 brakes and rotors will fit?
Old Jul 13, 2004 | 08:05 PM
EL Vap133's Avatar
TRAILING ARMS!! NOT LCAs!!! For the front you need KNUCKLES, NOT LCAS!
Old Jul 14, 2004 | 11:40 AM
Well what i was meaning was. Will the larger dc-2 calipers/rotors fit the 93 teg knuckles
Old Jul 14, 2004 | 11:46 AM
EL Vap133's Avatar
I used 95 GSR front calipers, rotors, pads, on my 90-93 Teg knuckles and they fit fine.
OnceIwasMuffin
Jun 20, 2018 06:33 AM
ziurek filmus
Suspension & Brakes
May 16, 2017 10:00 PM
classdork987654
Apr 18, 2009 05:27 AM
Loserkidwac
Mar 3, 2007 09:57 AM
typeR_EF_hatch
Feb 22, 2006 07:17 AM
